Ive had Two Rock Jet 22, Carr Mercury, Cornford Carrera, Carr Skylark, Blackstar Artisan 15 and for less than £100 it's amazing.
I run it through a Tone Tubby 1x12 and it's just great
Assuming it works and your not going to take it apart then there's little you can tell by looking at it externally .... other than physical damage to the wooden cab.
Having owned 2 of these for the last 4 or 5 years and gigged and modded mine I can tell you they are well made and very reliable ... mine have done literally hundreds of gigs and are just chucked in the van with no case. Both badges have broke off but other than that the amps have been fine. When you consider I'm driving the amp quite hard at every gig it is impressive.
The internal PCB is good quality and it doesn't look a difficult amp to fix if it does go wrong, the schematic is easily available and the opamp's and supporting circuitry are common parts.
There's an issue with the loops on mine where changing channels with a delay in the loop causes the delay repeat to be very loud at that instant.
They sound much better if you boost the signal between the send and return loop .... it makes a huge difference, I won't use mine without doing that ...it gives the amp a whole new character
@ecc83 and @ICBM know just about everything technical about these amps, my 2 pence is from a gigging perspective
There *is* a known fault with some of these - arcing around the phase inverter transistors. This is rare, but serious and will usually need a replacement PCB from Blackstar - they are willing to supply them. I can't remember for sure when the board was changed to the upgraded version with slots to prevent this happening, but Dave will know.
I think I like it best out of the HT series, in fact.
With that said the only known fault I had with one was the foot-switch sometimes wouldn't activate the overdrive channel but I'm sure this was just a loose connection somewhere rather than an actual factory flaw.
I had a tiny terror which was great but got sick of tap dancing and pedals.. it wasnt for me having been a line 6 guy practically all my playing life.. I fancy trying the HT5 in a 4CM setup..
" I can't remember for sure when the board was changed to the upgraded version with slots to prevent this happening, but Dave will know. " Well IC, been out of things for some time now...I CAN say that I am sure Blackstar will be as fair as possible with any customer's problem.
The tracking around the MOSFETs did not come about in my first time with the company. AFAIK any HT-5 that comes in for any repair gets the slots cut with a Dremel tool.
The FX loop problem was a pure mistake. I did the mod to a few and it is quite complex and time consuming, not something a tech could do profitably unless he charged an extortionate rate!
In any case, a Mk1 has to be getting on for 9 years old now? Anyone buying one should really budget for a complete check over at Northampton. The Mk ll should be all ok. The pre amp valve will probably last forever (but DON'T fit other than an ECC83 equivalent!) The 12BH7s seemed to live long as well but naturally get a much harder life. The fact that the circuit has been 'hacked' by at least 2 others means the 12BH7 could get short supply, bound to get expensive! Might be an idea to get one in now!
If you have DMMeter , 2 mini croc leads and a steady hand I or ICBM can tell you how to bias one.
Dave.
Also you refer to the MkII, is this the Reverb model?
