In the context of Valve amps that have no buffering just send and return jacks that act as insert points into the signal chain; devices suc as the Kleinulator do 2 things.
1. Adjust levels (depending upon where the FX loop is inserted, the signal levels will vary but are generally much higher than is suitable for FX pedals or even some rack gear.
2. Adjust source impedance - valves are generally "high impedance" devices which means that they are not suitable for driving low impedances without degrading quality (typically treble roll off is the most noticeable impact). Valves can be configured for this purpose e.g. Cathode Follower used to drive Tone Stack in Marshal Plexi style amps but when you create a simple FX loop by inserting jacks and not designing the circuit to match, you need an external buffer such as a Kleinulator.
