Board current draw will be 2x100mA toneprint pedals, a TU-2 and Frantone Vibutron at about 60mA each, and 4 other low-draw analogue pedals (chorus, boost, OD etc).
PSU will be diago micropower 9.
I've emailed Mooer to check what their max rating is for the daisychain but was wondering if anyone's using one.
Alternatively I could use two of the Diago daisychains linked with the unused plugs insulated, as I know they're sturdy, but a single 8-way would be neater.
I suppose eventually I'm looking to get a Cioks or something similar, but for the meantime it would be handy to run the board off one plug.
Yes, it will, standard Boss style barrel connectors on both
So so if you start to get noise, suggest a proper power supply
