Guitar is intonated but still sounds out of tune
ricorico Frets: 1220
My tele is intonated (as well as I can with three compensated saddles) but some notes on the B still sound out above the 12th fret.
It had a slight fret level recently but no crowning.
Are there any tricks to setting up a tele so the relative intonation is accurate?
Im using the Strobostomp iPhone app.
«13
  • sweepysweepy Frets: 4183
    Check the nut height first before you do anything else
  • ricorico Frets: 1220
    The nut height is spot on
    Have you retuned your ears? ;)
  • smigeonsmigeon Frets: 283
    Are the strings new?
  • richardhomerrichardhomer Frets: 24801
    How close is the neck pick up to the strings? Sometimes the magnetic field can impede strings' vibrations which can be perceived as an intonation issue.
    It's about 2.5mm from high E when fretted at last fret.
    That's not the issue then....
  • WezVWezV Frets: 16668
    Tune so the 5th fret note is in tune.  Then compare against the17th.
  • AlnicoAlnico Frets: 4616
    No guitar will play right with flat top frets.
    Have I misunderstood or are they actually flat across the top?
    I'm not saying that's the whole problem but i cannot understand why they would have been levelled without being recrowned?
    edited July 2017
    Jerry Donahue often talked about tuning his Tele and, thankfully, someone else had typed out how he does it.
    http://www.tdpri.com/threads/jerry-donahue-tuning-intonation-technique.197519/
    try this too.
    http://www.seymourduncan.com/blog/the-tone-garage/jerry-donahue-on-telecaster-style-bridge-intonation
    Maybe this will help.
  • FunkfingersFunkfingers Frets: 14423
    Are you a fretboard strangler? Some people press down so firmly on the strings that they send them sharp.
  • guitars4youguitars4you Frets: 14224
    edited July 2017 tFB Trader
    a couple of points to look at - tune up with a chord but no 3rd in the chord so root and 5th - a 3rd will give a dis-chord effect - try this approach further up the fingerboard as well - If you tune around the top nut end, then a slightly out of tune chord there will be amplified and further out as you up the fingerboard - so if you can tune around say the 7th fret and get this spot on/close, then less negative variation as you move up - Hope that makes sense as I'm not sure if I'm explaining it well
    also is the action high-ish or okay - a high-ish action is harder to intonate as you are effectively stretching and bending the string when you fret it - like a vertical bend
  • 57Deluxe57Deluxe Frets: 7338
    edited July 2017
    a typical extended intonation tweak on three saddle Teles is to slightly bend the E B saddle post laterally in towards the guitar's centre..
    <Vintage BOSS Upgrades>
  • peteripeteri Frets: 1283
    Try tuning on the 12th fret - and then playing across the rest of the neck.
    For example - my LP Special, in order to make the G string work - I have to tune it to a 'b' at the 4th fret. If I tune open, most chords sound out
  • crunchmancrunchman Frets: 11446
    That would be me.  I'm working at not pressing so hard but getting out of years of habit isn't easy.
  • RavenousRavenous Frets: 1484
    rico said:
    ...but some notes on the B still sound out above the 12th fret.
    Have you tried intonating on the 19th fret? i.e. play a natural harmonic above that fret, then play the note fretted. Tweak the intonation so these match.  (I think it's the 19th anyway - "two-thirds" of the scale length.)
    It's similar to intonating against harmonics at the twelfth, just on a different bit of the neck.
    I wonder if there's something else going on in the high notes, like pull from the pickup or some damage to the B string? (As everyone else's already mentioned the bridge height etc.)
  • earwighoneyearwighoney Frets: 3494
    It might be an obvious thing to state but have you tried changing the strings?
  • rossirossi Frets: 1703
    I set mine up to play the good old low D chord .If thats  sound right the rest does .no idea why
  • mbembe Frets: 1840
    When you say it 'sounds out', is that sharp or flat?
  • ChalkyChalky Frets: 6811
    No point changing intonation on old strings. They will have deformed at the bridge.  I always intonate to the 17th fret. So E open is A at the 17th. The guitar has to settle like that until next day then check again. And if all OK I check the 12th fret intonation too.  Some guitars just don't quite have every single fret in the right place.
