My main Strat has Lindy Fralin Vintage Hots in it. If you use DC resistance as a guide, then the neck and middle are around 6kOhms, and the bridge around 6.8kOhms compared with something like 5.7kOhms for vintage spec pickups. They have a bit more beef to them but they are still vintage in character. They aren't so hot that you lose the classic Strat sparkle.
I bought the Fralins years ago. There are a lot more home grown options now that would be a lot cheaper than Fralin. Something like Oil City Triple Blues would be similar.
Superb pickups.
Single coils have never really been my thing, although I have owned strats and frequently had HSS superstrats. Probably the only ones I've had I've come close to liking were the Fender CS69s in a 60s classic player strat I had a while back. Its only recently I've really come to appreciate the sound.
Also I do think the alnico 2 magnet poles help with getting a warm, sweet sounding version of strat tone - it's still very stratty, but perhaps not quite as edgy and bright as some pickups. A while ago I bought a couple of the steel base plates from Oil City, and I plan to try these on the bridge and neck pickups - but it's a nice-sounding guitar as it is.
I generally like slightly higher output pickups, I find less than 6k can be a little thin and bright (I struggled with CS69's) for that reason. Of course you can turn your tone control down a little to tame the brightness, but it's not the same as a higher output pickup.
Axesrus do an interesting range, but also see the thread about the cheap solderless Fender pickups.
If I were you, I'd skip the big companies like Fralin / SD and opt for something handwound from the likes of Mojo or Oil City from this parish. Ring them up, tell them what you want/like, guitar wood etc, take their recommendation and live happily ever after. Simples.
Both are noise cancelling but retain the single coil sound.
...one thing though impmann, presumably you meant to say Alnico 3 not 2 under the unwound strings...
Like what I’ve managed to hear of the Rocketfires
Sage advice imo re: skipping the big companies and opting for handwound closer to home
