Any Ozone 7 users on here? I am having a very strange issue with it - however only on one tune. The issue is that it sounds like a slapback delay has been put over everything in the file.This happens using Ozone as a plugin on the master bus and also as a standalone application. It does not happen on any other tunes. It does not happen on the PC based system of
@Luminous, who did the mastering. (I am using a macbook pro). It does not do it using different presets (Luminous saved his mastering as presets and sent them to me, the idea being that I could still tweak the multitracks and then render different formats as required.
It is most perplexing. If anyone has any ideas what is going on, I would be delighted to learn...
What DAW are you using? Is the slapback delay over one track or the whole mix? What happens if you disable Ozone?
Probably best to try switching each module on and off and seeing if it is a specific one, then you can try playing with the controls
Thanks for your contributions.
