Alternate picking slowing down
After pestering my tutor he finally gave in and we've been looking at improving my picking technique.
He gave me a couple of exercises to do - a couple of repeating patterns over a couple of strings and a major scale pattern that covers 5 strings, all 16th note based - which I've been practising regularly since he gave them to me a few weeks ago.  At first I was noticing a slight improvement and could do 5 repetitions of the major scale exercise cleanly at 116bpm and 2 or 3 repetitions at 120bpm before things get messy (the two string exercises were slightly faster).
However the last couple of practise sessions I've put in I can barely get through 5 repetitions at 104bpm.  I've not been practising through pain and I haven't (to the best of my knowledge at least) changed my playing position.  Everything just seems to fall apart when I push the metronome any faster.
I dare say that my picking below this speed is cleaner than it was but I'm finding the decrease in the top speed a bit disheartening.
My tutor is on holiday at the moment so I'm deferring to you lot for encouragement and (hopefully) and explanation of what's happening  :)
«134
  • What subdivision are you doing the picks at? E.g 1 note or 2 notes per beat?
    Try raising the tempo but keep it quarter notes (1 per beat). When you feel confident then add in a second pick so its 2.
  • RedRabbitRedRabbit Frets: 486
    It's 16th notes so 4 notes per beat.
    Changing the subdivision doesn't seem to help any.  As soon as I get past 16th notes @ 100bpm (or 8th notes @ 200bpm) it's as though my picking hand just can't move fast enough anymore and I'm getting the plectrum caught up in the strings.
    I was happy that I had made some progress building up to the 116bpm mark and thought that if I kept at it I could add maybe a few bpm a week/fortnight/month and make steady progress with it then I could actually see me sticking to the practice regime this time.  The fact I'm now struggling to get past 104bpm is baffling and quite demotivating.
  • octatonicoctatonic Frets: 33782
    edited August 2017
    Spend more time playing it slowly.
    Speed is a byproduct of accuracy.
    Once you hit your performance limit you can look at adding about 5 bpm per week if you are diligent in your practice and don't rush too much.
    That is about as good as it gets.
    Most people aren't well organised or diligent enough and it ends up being 5 bpm a fortnight or a month.
  • Maybe try tackling 2 strings at a time, then add another as you get confident you've done it 4 times no mistakes.
    What sort of approach would you suggest? At the moment I warm up with chromatic exercises at 16th notes @ 80bpm and then start going through the exercises at this speed. Once I've managed 5 clean repetitions I'll bump up the tempo (on the setting I'm using the metronome goes up 4bpm at a time) and repeat until I get to a point where I can't complete more than a couple of clean repetitions. At this point I'll back off the tempo a bit (usually 8bpm) and try to do 5 clean repetitions to finish off with. I'll then take a quick break/shake my hands about a bit and then repeat with the next exercise.
    5bpm a fortnight or even a month would be fine as long as I can tell I'm making progress. It's this backwards step that's concerning me.
    I seem to have hit the same barrier with the 2 string exercises as I have with the 5 string exercise. I can maybe do a few bpm more with the 2 string exercises but it's still slower than it was this time last week.
  • I'd be interested to see your picking hand position as well, do you rest any of your fingers on the pickguard area? Sometimes it helps keep the hand stable.
    I tend to rest the outer ridge of my wrist on the bridge.  I never got on with resting fingers on the pickguard.  It seems to stiffen my wrist up - I'm more relaxed with my fingers curled under in a loose fist.
    This is the only picture I've got to hand of me playing
    http://imgur.com/Wcv4H44
  • I find sometimes just putting the 4th (pinky) finger on the pickguard helps with stability. Or if picking the lower strings to rest on the higher strings to mute them off too.
    Like I said, I've never got on with that approach before but I'll give it a go.
  • Also are you holding the pick with thumb and first finger? Some hold with thumb and 2nd or more than 1 finger and it blocks the pick a bit. And have only a little bit of the tip showing!
    Yeah, thumb and first finger.  Used to use thumb and second but forced myself out of that habit a few years ago.  I don't tend to have a lot of the pick showing - maybe 2 or 3 mm.
    Edit - found a pick on my desk, this is how I hold it
    http://i.imgur.com/9vB0cMm.jpg
  • That's good, position pick 180 degrees parallel to the string as well to get the optimum contact!
  • Is it that you're paying more attention to cleanliness now instead of blasting through?
    Would help to see the exercises in detail...see if there are any obvious hurdles.
    I'm not a shred-monkey but I have been conscious about pick-slanting for a while now...it's helped me improve some awkward runs.
  • stratman3142stratman3142 Frets: 2193
    edited August 2017
    I'm not sure that applies to all players if you look at the picking technique of great alternate pickers such as Paul Gilbert, Andy James and Troy Grady (for example) where their pick hits the string at an angle.
    I wasted a lot of time under the idea that the pick needs to hit the strings squarely, which resulted in an awkward approach to picking for me.
    It's not a competition.
  • Depends what sound you want, but if I turned mine to the side it'll fall out my hand!
  • vizviz Frets: 10681
    I would focus on playing musical tunes rather than a certain bpm if I were you.
  • sweepysweepy Frets: 4180
    I know that Shawn Lane was a bit of a freak but he recommended playing something at the speed you want it to be, not learning it slowly and then acheiving the speed you require, must admit I sit in both camps a little on that
  • mike_lmike_l Frets: 5700
    @RedRabbit ;
    It sounds almost like you're practising these exercises too much. Try 5-10 repetitions of each and move on to something else. Having a piece which is a direct replacement for the exercises works really well. So if you're working on alternate picking, find a piece which is just alternate picked. There is plenty to choose from, and spend time working on the performance piece as well as the exercises.
  • digitalkettledigitalkettle Frets: 3222
    edited August 2017
    Can't argue with this but it's fun to work on technical facility every now and then.
