1/4"
A lot of blanks do come thicker. you can use thicker or thinner as long as you allow for it in the overall neck thickness and truss rod depth.
Instagram
yeah, its not uncommon to have fretboard blanks up to 10mm thick - usually un-planed at that thickness though.
You normally don't want it any thinner than 5mm
A lot of places supply thicker as it gives options. Some classicals can be nearly 10mm thick. Also, it allows some fudge room if the wood moves and needs to be re-surfaced
Instagram
