I'd have to check whether you can run the head safely without a cab connected by I suspect HK have designed it to be fine - double check it though before you try.
The amp switches to a zero watt mode, or words to that effect, once it realises there is no load connected. Quite clever really. As for a headphone amp, am I looking at something like this?:
http://www.dv247.com/headphones/behringer-ma400-micromon-ultra-compact-monitor-headphone-amplifier--38127
Where I'd run the amp into the 'mic input' XLR input.
Could be some conbobbulations... ? First off, I have that HA400 H/P amp and they are really good for the money. Now, that XLR output* is 'balanced' and of course Mono. If you want signal in both ears you will need to use an XLR to STEREO jack plug lead/adaptor which picks off just the 'hot' XLR signal on pin 2, pin 1 should be common/earth. The ring and tip of the jack plug need to be linked. I doubt you will find such an adaptor so you might need to solder your own.
*I am annoyed by guitar amp mnfctrs (yes! I know!) that fit XLR 'DI' outputs but run them at line level. IF it is a standard DI it should be MIC level (and balanced, preff with an earth isolated traff) If line level, use a jack FCS!) There are other possible circuitory traps here but I shall K.I.S.Sir for now.
Dave.
Just had an email back from H&K basically confirming the same thing, that the DI out is at line level.
They only advise to make sure that the headphone amp has a line level input rather than a mic level input.
https://www.amazon.co.uk/gp/product/B0002L05XY/ref=oh_aui_search_detailpage?ie=UTF8&psc=1 and knocked up a little XLR to jack lead and plugged into the channel 1 line in (not the XLR input as the GM has too strong a signal). You can then plug a music player into one of the other channels and widdle away.
Yes, a mixer will work because you can pan a single source to central, both ears.
Dave.
Thanks for your help both of you.
I think I'm sorted now, one of these XLR (F) to Stereo Jack leads, and a little mixer as linked above and I'm about there I think!
http://www.gear4music.com/G4M/XLR-F-Stereo-Jack-Cable-6m/109Q#full-des
