Soz; being lazy. Details below.
SOLD First up is a DeWalt 2000W 1/2" DW625E router. It comes with a very sturdy DeWalt case and also a Trend FHA/003 fine height adjuster, which is invaluable when it's in a router table.
Located near Norwich (Norfolk, NR12) and available for collection or I could probably post at buyer's expense.
Looking for £150 PayPal Friends & Family.
SOLD Next is an Axminster WHRP Cast Iron Router Table.
It can be unbolted and flat packed if you need to get in a car or I could strap to a pallet for delivery at buyer's expense.
Excellent top quality router table, was over £400 new.
780x250 cast iron table with slightly larger sliding/extending aluminium table.
850 height.
45 degree tilt for easy access to fit/remove router.
This Router Table is a heavy and well specified accessory suitable for a wide variety of routers and applications. The heart of this table is its finely ground cast iron table which provides a solid and stable foundation for all functions. When you consider the weight, power and speeds of modern 1/2” routers the importance of a solid table should not be underestimated and weighing in at 56kg is one of the heaviest on the market, with the wide base and angled legs adding even greater stability.
In addition to the main cast table, there is a sliding aluminium table with cross cut mitre fence and hold down clamp for undertaking end grain work. The main fences can be set independently and feature micro adjustment. The table has three pairs of tapped holes so the fence can be easily repositioned to accommodate different sizes of workpiece. Also, when profiling, the fence can be reversed so the operator does not need to lean over the sliding table and can work comfortably from the other side of the machine utilising the main cast table itself. A dust extraction hood is fitted to the main fence and guard area and a no-volt release switch is included.
Located near Norwich (Norfolk, NR12) and available for collection or I could probably post at buyers' expense.
Looking for £300 PayPal Friends & Family.
Finally, a Charnwood W715 10" Bench Top Bandsaw.
A larger bench top bandsaw with a durable precision ground cast iron tilting table, with a stop for returning to 90 degrees afer making bevel cuts, and T shaped mitre fence slot. The quick release fence locks securely onto the front rail of the table to provide a rigid straight guide for ripping. A magnifier is included to aid accurate setting of the fence along the scale, marked out in mm. The cast metal sliding mitre fence can be locked at any angle and has an adjustable support fence. The new blade guard design is adjusted and locked y using a dial on the side of the machine and is fitted with a scale to quickly set it to the correct timber height. Two side guide bearings and a rear thrust bearing on the end of the guard, control the blade and keep the cut straight and true.
Supplied with a rip fence, mitre fence adjustable 45 degrees each way, NVR switch, push stick, cable and plug.
Looking for £200 PayPal Friends & Family.
Shame
Are you closer to the city or the coast in NR12?
Just north of the city by 10mins drive - village called Coltishall.
