Super fine sandpapers?
I'd like to finish my Wudtoned guitars with sandpapers, running from maybe 1000 grit to 4000 before applying a polish to get them proper shiny and smooth.
Obviously, Wudtone finishes are proper thin so I have no use for anything in heavy grits, it's really just to put on a block and very, very lightly smooth everything off.
Bloody rip off, I don't want to partake in that!
  • Micromesh is really good mate. Not the cheapest, but it's cloth backed so it lasts for ages.
    http://www.amazon.co.uk/Polishing-MicroMesh-Finishing-Flexible-Sandpaper/dp/B003RTABUK
    But... The postage...
    It comes in an envelope, it shouldn't cost that much! Surely there is another dealer out there who doesn't do insane postage profit?
  • There may well be. I think Axminster stock them...
  • DeadmanDeadman Frets: 3851
    Pming you pd.
  • t1000t1000 Frets: 93
    I have brought fine wet and dry from halfrauds in the past. I cant remember exact but im sure they do upto 2000 grit at least
  • martinwmartinw Frets: 2149
    On one vid I watched, the guy recommended a sheet of A4 copier paper.
  • GSPBASSESGSPBASSES Frets: 2335
    edited February 2014 tFB Trader
    Try D D he does a pack of 9 for about £14 these go form1200 to 12000 grit they can be used over and over again as they can be washed out after use then used again.
  • vizviz Frets: 10644
    Consider fine wire wool from b and q.
    Already got some wire wool, and while it's fine, it's a bit too abrasive for polishing up.
    Cheers mate, I'll definitely look into that!
    @deadman has been super generous and is sending me a couple of bits of his, so it'll get me out of trouble and let me know what I need to buy.  I reckon that set will be great though, 12000 grit!
  • @GSPBASSES, that guy sells literally everything I could need, bookmarked for future reference.  Thanks!
