https://www.youtube.com/watch?v=shAtnDUXGlQ&feature=youtu.be&t=26m30s
Fortunately it sounds good at any setting!
Pound to a penny that no truly great guitar music has been recorded through an amp set up in this way....
Turn the knobs until it sounds good, all of this method is just Internet flannel.
That's true, but there are quicker and more effective ways off arriving at it, and slower and less effective ones.
I was initially sceptical about the 'Matt Schofield method' when I first read about it too, but having tried it, there really is something in it. At the very least, turning each control through the full range and listening for the 'most change point' will let you really hear what it's doing, which gives a much better idea of how to set it for what you want if it's not there - but perhaps surprisingly, it does often seem to be. Give it a try...
I would repeat that I think it's fairly pointless without playing through it though - just dialling the amp in to its own background noise probably isn't going to make it sound any better. It may give roughly the same result, but why bother? You still need to play through it to tell.
If it was about hitting that point just before clipping increases steeply so that the dynamic range of your picking gives you the most tonal control, that would make sense. But on any amp with a tone stack and more than one volume control there are multiple combinations that could get you there.
The tone controls are there to give you the tonal balance you want with different guitars - and as others have said - will affect the gain structure of the amp as a result.
This smacks of hi fi tweakery. I'm perfectly happy with my ears telling me what sounds right. By definition - unless an amp is only capable of giving one 'perfect' sound - this method cannot be viewed as the 'only' way of doing things....
Anyway, I'm with @timmysoft on this. Turn the knobs until you like the sound that comes out. Set to taste, play, change mind, set to taste, play, before you know it you've lost four hours which, to me, is all the fun of getting a new amp anyway.
If you have to do it quickly then you're probably either a touring guitarist renting amps, or a studio producer with lots of your own - in either case you'll have a pretty good idea of what you're going to do anyway.
Remembering that mag column, I've tried the MS technique a few times and, while it's probably quicker, I'm not convinced it's any more effective but then (outside of gigs) I'm an inveterate tweaker of knobs anyway.
But I get the concept of pots not tapering perfectly and finding the limited area(s) where they affect the amp or sound the most, and taking it from there. Kind of makes sense in that way. Maybe those are the "sweet spot(s)" to sheep's ears, for some reason the sheep can't quite fathom.
