Repeating the light show is a bad idea if you can avoid it. It's possible that some amp damage has already occurred, but if it hasn't then it's better not to risk it. If you closely inspect the valves it may be obvious which is the culprit - the printing on the outside or the grey plate on the inside may be discoloured, or the getter may be thin-looking or even turning white, depending on how bad the leak is. (This can sometimes develop over a few days.)
If you can't tell, I would replace all four power valves - which is best done as a set anyway - and see if the amp works OK. when the new valves are in, check that all of them glow correctly when switched fully on - you should be able to see a faint blue glow inside the plate structure as well as the typical orange heater glow. If any of them don't, the chances are that the bad valve has burned out the screen resistor as well.
Don't throw the old ones out yet - the faulty one may show itself after a while, or if not then you could get someone to test them for you. The other three will be OK, almost certainly.
This is the colour of an Argon lamp, you will probably recognise it .
https://upload.wikimedia.org/wikipedia/commons/5/53/Argon-glow.jpg
If it is, it's the shrinking valve socket which has cause a power valve to crack around the pins and let air in - and if so, do *not* fit new valves until the sockets have been changed, or they'll go the same way.
How to tell - remove one of the power valves and have a look at the pins. If they're bent inwards towards the middle of the valve, the socket has shrunk. You could look inside the amp as well, and if the sockets look like this (this is a Marshall, but they're the same type) then they must be changed - notice how they're discoloured, look melted and no longer exactly round.
Good news is that the valve bases look a little 'tanned' but still round with no bent pins on the valves.
Bad news is that I replaced the dodgy valve but the amp wouldn't switch on at all. Checked the fuses and they seem ok and can't see anything obvious on the top of the PCB. Sounds like it might be time to get it to an engineer.
Having a good week - Samsung tablet died, central heating boiler died (and the heat exchanger) and now this - maybe time to write an epic ( obviously acoustic) blues song.
This fuse has blown, which is excellent news. Just need to get a new fuse and see if the replacement valve does the job.
The blown valve most likely shorted from cathode to filament as well as plate to cathode (in fact it may have simply shorted everything, if it had got ionised!) which will take out one or both these fuses. They're T6.3A, if you need to get more before you start.
I'm not a big fan of filament fuses to be honest, they quite often 'nuisance blow' for no good reason, and they don't really protect the transformer much better than the primary fuse.
Power the amp up and meter from the chassis to both ends of each of those fuses, with them back in place - you should read just over 3V AC on all four points. Then meter across from one fuse to the other, or from TP1 to TP2 on the board - you should get 6.3V AC.
Again, many thanks for the help - much appreciated. ICBM and DJH83004, if you are ever in the Wokingham area, I owe you a beer or two...
Steve
Let's hope it's not some other intermittent fault...
No problem .
