I am finally getting around to installing a set of Graphtech Ghost saddles and the associated preamp into my long suffering Tele. Initially I thought about housing the battery in the control cavity or under the pickguard, but in the long term I know that these locations aren't ideal as it's hardly quick access and eventually the wood will no longer hold the woodscrews. So, whilst everything is in pieces, where is a good place for me to put a battery box? As the wiring needs to run via the jack socket (to switch the preamp on and off) I thought about locating the battery box on the back of the guitar somewhere behind the bridge but close to the tone control end of the control cavity. However, having looked at a few images on the web it seems that in instruments fitted with the Fishman Power Bridge, Fender put the battery box on the back of the guitar in an area behind the pickguard near to the switch end of the control cavity. What are the pros and cons of the two potential locations? And what battery boxes do people prefer? The Gotoh one seems to be readily available but I've seen a few others as well.
Edit: having looked at more images on the web, it seems that Fender also used the location that I have proposed - perhaps changed at some point in time, or US versus Mexican manufacture?
Cheers, CasperCaster.
Plastic battery holders often break, as well as being ugly.
have you tested where the pre-amp is going to go too? You can run out of space in a tele control cavity pretty quickly.
I would just go under the main plate as long as the neck pickup isn't scratch plate mounted. If you are worried about the wood you could use push in inserts rather than screwing directly into the wood. Honestly though, it will be fine without
Instagram
https://i.imgur.com/0qQgtiS.jpg
To date the Tele look like this. It currently has regular Graphtech saddles installed so I can set the intonation before committing to drilling the bridge plate.
https://i.imgur.com/fdBekHq.jpg
http://www.thefretboard.co.uk/discussion/89942/caspercaster#latest
