I am considering a getting a replacement neck for my strat - it currently has a maple neck with rosewood board. A few years ago I had a Musicman Albert Lee that had the most sublime birdseye maple neck & 'board, and it's this combination that I'd like to retrofit.
Assuming that I order a new neck from Warmoth (with a nut fitted and slotted), is it just a simple case of swapping over the neck hardware and offering the neck to the vacant neck pocket and securing in place with the old screws?
Is there anything more that I need to know / check, or is it that simple? Are there any jigs / fixtures / procedures required to ensure that the neck is sitting flat and snug in the neck pocket?
All advice welcome.
Get it pre drilled from a reputable maker.
Both Warmoth and Musikraft are great, they will drill perfectly for fenders and file the nut for your gauge. You can simply install the neck, line it up nicely and see how the action is, if you need to raise or lower your bridge dramatically then you will need a small shim in the neck pocket (usually the thickness of a playing card).
You will need to set the neck too, think carefully if you want the truss ross adjuster on the headstock or at the heel. I start usually with the neck straight and see the natural relief with the strings on and under the right tension, then re-adjust.
Be careful installing the tuner bushings, do not hammer them in. if they are too big to push in with normal force then you need to ream the tuner holes. The trick without a proper tool is to roll a sandpaper piece and use that.
Also put a bit of hard soap on the neck screws.
Pre-drill the holes to the tuner screws very carefully, the drill bit must not go too deep. It you do not pre-drill they screws will snap.
No worries, I assemble my own now so if you are stuck at any point I am happy to help.
It is not as bad as I made it sound!
