When I went through my Hendrix worship phase I bought a left handed American strat, reversed the nut, restrung it and played it right handed - seemed to be a no brainer for any Hendrix wannabe to do. You're getting the whole experience (no pun intended) - reversed pickups, neck, tremolo, view when you look down etc. Why is there a market for ordinary strats with reverse necks, and why are some of them called Hendrix strats? Why did SRV play (I think I'm right in thinking) with a reverse tremolo only?
If you want to do what Hendrix did, then do it - turn your whole guitar - whether it be a Stratocaster, Flying V, SG or Guild 12 string -, upside down, not just the neck or trem.
SRV did the trem, because (from what I've read) he thought it would change the feel of the trem to let him copy Jimi more.
The upside headstock is to do with changing string length, which I always thought was clutching at straws to say the least!
People do the reverse headstock thing presumably because they think it looks good. Not my bag, looks weird to me.
The upside down pickup makes more sense to me. Well, more sense than having to rake your forearm over a trem arm, three knobs and a switch, and the jack lead which is now pointing straight up at you.
Agreed, (except for the ones attached to Rob Chapman guitars. I'm being childish - but I think he's a tosser)!
Made it easier to play a regular strat in that counter intuitive position. To be fair he sounded unbelievable on anything.
The reverse headstock makes quite a big difference to the feel and bend range when bending strings or using the trem - it makes the top strings much stiffer and able to be bent further, and the low strings looser and less affected. I doubt it changes the tone much or at all when you aren't doing either of those things.
Likewise the reversed trem does feel different, even though the overall movement is the same because the block is solid and it doesn't matter which side the force is applied - it's just how it sits under your hand relative to where you normally play.
The reverse bridge pickup changes the sound of the bridge and the bridge/middle positions because the mix of harmonics on the strings is different, and the reversed stagger of the polepieces changes the string balance too.
That said, even with *all* that, someone who can play properly like Jimi will still sound more like him on a plain right-handed Strat played right-handed than someone who can't on a fully reversed Strat will.
