Hello
My Strat is currently set up with the trem floating which isn't for me as I don't use the trem and often end up pushing the trem back with my palm.
I'd like to set it flush - if this simply a case of detuning, crewing the claw in further then tuning back up?
Currently the guitar plays wonderful thanks a to an excellent setup job from a shop and I don't really want to ruin how it plays. If I did this would I have to get the setup sorted again?
But when the bridge plate is flat, the scale length will be microscopically longer until you adjust the saddles and aslo the action may go slightly lower.
Worst case is a tweak on the truss to make it slightly more concave but I doubt you'll need to do it, unless you've jacked the plate up on housebricks for slide or something......
I assume it has 3 springs currently in use - without looking how much travel you have left on the claw screws (and there generally should be enough) then yes de-tune and turn the screws by the claw until it sits flush - re-tune and check and adjust again if required - at this point if you still want to use the trem for down pitch only, then adjust claw screws accordingly so only a light touch is still required on the trem - hope that makes sense
Other option is to go with 4 or 5 springs - some like this as the feel extra springs and trem plate flat to the belly of the guitar gives more 'vibration/resonance' from the strings/bridge into the body - not so good an idea if you still want some down pitch - can be achieved but more muscle power required on the trem arm itself
Other option is the Clapton style of a wood block between the trem block and the body - But to most then either of the above 2 options should be ok
Not sure of your desire and ability to adjust - easy for many to say it is easy to do but if unsure then I'd suggest a visit to the guitar tech again
