Diezel vh4 pedal
nick79nick79 Frets: 252
This pedal has caught my attention, watching a few youtube review vid's it seems to sound ok but i'm always a bit wary of (expensive) distortion pedals - They never really seem to match up to a decent amp at full chat... I wouldn't mind a bit of VH4 tone in my life and alas the big amp is way over my budget.
Anyone here tried one? If so wouldn't mind hearing your thoughts.
  • It's really great! Genuinely fantastic pedal and worth it if you need a high gainer. Look out for the new version coming soon though which has dual channel. It is incredible for lead work, really thick and creamy.
  • nick79nick79 Frets: 252
    Ace, sounds great, thanks for that. Do you have one yourself? Would be interested to hear what you run it through. I don't really need  one, but i'm thinking if it's different enough from my Mini Rectifier on modern mode i could find a use for it.
  • I'm not sure if the mini rec is like a Dual Rec, if so, then I wouldn't bother, you've got enough gain on tap. If it's not, then it could potentially be good for you?
    I ran it through a Laney Lionheart 20w head on the clean channel...brutal :-)
    Would buy again if I had an analog setup, but I'm all digital now.
