Schaller & Wilkinson Roller Bridges
SaddlepunkSaddlepunk Frets: 47
edited September 2017 in Other Reviews
It seems odd to me to have a bridge with sharp saddles on a guitar with a Bigsby tremolo. When you use the tremolo the strings are going to be reluctantly raked backwards and forwards over those sharp edges. Bad for the strings and bad for the bridge saddles.
I've got an Epiphone Riviera. The first thing I did when I got it, or rather refrained from doing, was to use the Bigsby - I just couldn't bring myself to haul the strings over its factory fitted, Bigsby unfriendly, tune-o-matic, bridge soI did some research into roller bridges. I liked the look of the one Wilkinson made, but couldn't find it in gold and decided it was off-puttingly inexpensive so I ordered a reasuringly expensive gold Schaller from Stewmac in the US.
The Schaller had the same dimensions as the stock tune-o-matic so was very simple to fit. It seemed well made, had loads of micro adjustment, forwards, back, side to side, on the roller saddles but I didn't like the way it sat on top of its height adjustable locating pins with no locking mechanism, and, probably because of that, I could see it rock backwards and forwards when I used the Bigsby.
I didn't like the bridge moving around, but I wasn't going back to a non roller bridge so I put up with it until last week when I found that gold Wilkinson roller bridges were back in stock at Axesrus. Actually that's not quite true, I revisited the roller bridge thing by, for some reason or another - I can't remember why - buying a very cheap Wilkinson copy on Ebay to see what it was like. It was dreadful, horrid, a complete waste of money that was never going near my guitar, and it was then that I found gold Wilkinsons in stock at Axesrus.
The bridge arrived this morning and I've just fitted it in the past hour or so. It was fairly straight forward (would have been much easier if I had removed the strings instead of being lazy and just loosened them) but I had to be brave and re-drill the bridge post holes a little bigger and press in the threaded pieces that the Wilkinson arrived with. I also had to reverse the two middle saddles to get the intonation right.
My verdict is that the Wilkinson is much better than the Schaller (not least because it has grub screws to lock the bridge onto its posts) and costs less than half the price.
Could be my imagination but the guitar sounds brighter - as if I'd fitted new strings.
https://i.imgur.com/h7FIouU.jpg
Schaller roller bridge - slightly out of focus - my apologies.
https://i.imgur.com/8UTAtn7.jpg
The underneath showing there is nothing to lock the bridge on its posts.
https://i.imgur.com/nUHsTwc.jpg
Wilkinson roller bridge - I would have liked a very similar one made by my favourite locking tuner maker; GOTOH, but I think they've stopped making them.
https://i.imgur.com/LXberqx.jpg
  • I use these roller bridges in most of my guitars, after while the wheels gum up and get stuck but they are so cheap you cn just buy a new one £6 on ebay.
    If I remember rightly it cost £6!
  • JeremiahJeremiah Frets: 631
    I got the Schaller roller bridge, not to use with a Bigsby, but because the rollers roll from side to side to allow you to adjust the string spacing and I find the standard tuneomatics to be a bit too narrow.
    The downside of this is that it's quite easy to unintentionally change the string spacing when replacing strings etc.
    I do think there is a slight change in sound compared to the stock (Gotoh) tuneomatic; a little less bass, and a kind of high frequency "chirp" at the attack of each note.
  • FlipFlip Frets: 68
    edited November 2020
    I experimented with a roller bridge on my Gretsch 5420T and went back to the adjusto-matic supplied - mainly because I like as fast a fretboard as possible. My adjusto-matic was sitting on the thumbwheels at their lowest and the roller bridge was significantly higher, the result was an unacceptably high string height. Plus the original bridge actually rocks slightly which reduces the tuning and wear considerations and avoids the tinnyness the roller bridge produced. Additionally the supplier send thumbwheels and posts that weren't as shown in the photo so I had no alternative other than carving down the wooden part of the bridge. I'm not that brave!
