I've got a strat body and I want to fill the tremolo cavity so I can repaint the body and there'll be no sign it was ever there. I have neither the tools nor the skills to make a solid wood cavity block like hipshot make, and it's left-handed, so I can't buy one ready made.
I had an idea to create a 'paste' from wood glue and sawdust and then fill the cavity with this. Once it's dry, sand it flat, repaint the body, fit a hardtail bridge and hey presto!
I won't be the first person to have thought of this, so are there any pitfalls? Will it work at all? Will the dried 'paste' be strong enough to screw the hardtail bridge into?
Bandcamp
if you were doing it properly even the properly shaped plug won't be invisible after a year or two of natural wood movement.
Instagram
1. Set the bridge tightly flat on the body.
2. Turn the guitar over and fill the trem cavity up to the top of the block with clear casting resin. Do not remove the springs first.
As the others have said there's no way to do this completely invisibly even if you fill it with matching wood and paint over it with a solid colour - you'll always see the outline once a bit of wood movement occurs.
If you want it invisible, you need a new body. If not, just block the bridge.
