I'm trying to resurrect my long dead Peavey Profex. I'm sure there will be multiple issues to address but my first order of business is replacing the data switch.
One of the wafers on the data switch has broken so I am looking for info on the data switch. The data switch is one of these multi wafer rotary switches that spins indefinitely in either direction allowing parameter adjustment. I have contacted Peavey but no reply so far and had a trawl of the Peavey forum without any joy.
I'm looking for info to identify the type of switch so I can try and source a replacement, Anyone got any info or ideas?
It was a mechanical encoder potentiometer but i cannot remember the model no etc.
I got the model number etc from the side/underside of the unit and checked here. They have a few different types so you may have to dig to get an equivalent part.
http://uk.mouser.com/
http://uk.mouser.com/Search/Refine.aspx?Keyword=encoder+pots
IIRC mine was an Alps unit which seem to be used a lot for these types of data encoders etc.
http://www.alps.com/WebObjects/catalog.woa/E/HTML/Encoder/Encoder_list1.html
https://www.google.co.uk/#q=Alps+encoder
Hope that helps.
