Seriously though, he's very generous with his knowledge of all things Getschy.
Note: the bridge base will need to be fitted to the guitar top. Use masking tape to hold some sandpaper in the bridge area, and run the new bridge gently back and forth until the contact points match the curve of the guitar top. It has a big effect on tone and stability.
Also, if you are planning to use an existing bridge (Compton, Rocking bar, roller or tunomatic etc) note that Gretsch use a variety of post spacing sizes depending on the model, or signature model. Typically, it’s 3”, or 2.9”, but some rate models have unusual spacing. So check the new one has the correct spacing before ordering.
Best of luck
Marlin
