FS: Bigsby B5 Tele kit (MJT reliced), Tele Hardware (Fender, Oil City, etc)
redrighthandredrighthand Frets: 746
edited October 2018 in Guitars £
- EDIT - NOW SPLITTING FOR PARTS AND MORE ADDED - SEE BELOW -
So, with another Tele partscaster half way built, and having realised I prefer the tele partscaster I already have, I’ve decided to move this one on and make a little room. I’d rather sell it all as one - however if there is no interest will break it back down and sell it as parts.
So have a look at the pics. It’s a Bigsby B16 equipped Tele, with a Guitarbuild body, Allparts neck, Oil City and Fender pickups, and 5 way switching. I’ve detailed the parts below. I’ll sell it as a job lot for £350. Note that it does need a setup, and I have found the wiring a bit noisy - so not sure if it needs shielding or grounding properly.  Further info (good and bad) on all the individual parts is below. IMO it looks fecking awesome but needs a decent setup.
https://i.imgur.com/EHOPcoS.jpg
Details and prices if sold separately:
  • Pickguard: El Dorado leather hand-tooled. These sell new for a mental $100: £25 NOW SOLD
  • Body: Guitarbuild pine - finished by me in tru-oil and bro-wax following the WezV technique - albeit to a much more amateurish standard! Has an unfortunate dent on the top as pictured - and various smaller scratches though nothing as serious. If someone wants this separately be aware that it is drilled for a rocking bridge and will come with the thimbles fitted - these may be tricky to take out as they were a tight fit. The holes are wider than a standard tele control plate so would need filled if you want to make a standard tele out of it. Beautiful grain.: £30  NOW SOLD
  • Neck: Allparts TMO FAT. These are awesome chunky necks - an inch thick all the way along.  A few things to note. 1. The nut isn’t glued in and was one of my first attempts at cutting one. You can have it, but may want to do it properly. 2. I’ve rounded off the fret ends as these come from the factory quite sharp. I think I did a decent job, though I did it after Tru-oiling it and went through the finish around a few frets (see pic - though not massively obvious). Basically do not expect a pro job! 3. The tuners are for sale separately (see below) but the ferrules will be included as they’ll be a bastard to get out. 4. It’s been drilled for this tele with the shim. I can’t think that’ll make much difference if fitted to a normal tele - but will leave it to others who know much more about this stuff to confirm. Price reflecting all of this: £60. NOW SOLD
  • Bigsby USA B16 plus genuine Bigsby Neck Shim. As pictured. Doesn’t come with a bridge but includes the shim and all screws, spring etc. The screwdriver slot on one of the end screws is quite worn - limited life in it - though it’ll be simple to find a replacement if required. £100.  NOW SOLD
  • Tuners. These are the nice Axesrus kluson deluxe copies. Not including the ferrules (see above). £15. NOW SOLD
  • Wiring. Solderless. 5 way switch. Bought on here some time ago. £25 (not including control plate/knobs but including the switches and pots obviously). NOW SOLD
  • Bridge Pickup: From an AVRI 52 reissue - it’s unbranded but I used to have a 52 reissue where it came from.  £25. NOW SOLD
  • Bridge: this is from an AVRI Jag or Jazzmaster (can’t remember which) so a genuine fender part. Note if you are interested in the lot that it is currently sitting on two wooden shims inside the thimbles - as the screws aren't quite high enough on their own to suit the neck angle. £25
  • Neck plate and Screws: unbranded. £5
  • Control plate and domed knobs. £10.
MORE ADDED -
Bigsby B5 Kit - Reliced by MJT in the states. Never fitted. £185 new and the relic job cost a bit too. £140!
https://i.imgur.com/uKNHNSX.jpg
Allparts Tele Pickguard - white single ply - still in packaging. £10.
https://i.imgur.com/Y5bRp0u.jpg
Seymour Duncan Lil 59 for Tele bridge pickup. Boxed though no mounting screws. £25. NOW SOLD
https://i.imgur.com/ShmCjuO.jpg
Reliced chrome neck pickup mounting plate. £5
https://i.imgur.com/hnZBAcI.jpg
BROKEN tele neck pickup from a 52 reissue. Repeat - broken. Postage cost if anyone wants it. NOW GONE
https://i.imgur.com/J1PomAj.jpg
https://i.imgur.com/7nZrTWr.jpg
https://i.imgur.com/vY4XrFs.jpg
https://i.imgur.com/lMgUDcd.jpg
https://i.imgur.com/XWEp3Rl.jpg
https://i.imgur.com/kEij8wA.jpg
https://i.imgur.com/4FVfDMl.jpg
https://i.imgur.com/iEynNLR.jpg
Everything is in Leeds.postage extra.
Questions / need more pics - drop me a PM. :-)
  • DrBobDrBob Frets: 3006
    edited September 2017
    If you do break it for parts then An Allparts TMO Fat for £60 ? Yeah go on then I've a build for a mate that will work on, so I'll have that. PM me your details !
    Although looking at it again it's a good looking piece, it would be a bit of a shame to pull it apart .
  • Cool no worries DrBob. Let me give it a few days to see if anyone wants the whole lot!
    If you break it for parts, I'll take the Bigsby please....no rush......
  • Ok so that's dibs called on the neck, the bigsby and the pickguard.  Everything else still available - as is the entire guitar (for now).
  • Hmmm at £30 I could be tempted by that body...pm me if you decide to split.
  • Any interest before I split?
  • I'll take the 52 RI bridge pickup please.
  • To all who replied: looks like I'll be splitting. Will be in touch next week with details!
    The following bits have had dibs called:
    - pickguard
    - bridge pickup
    - bigsby
    - neck
    - body
    Everything else still available.
  • Definitely splitting for parts now.
    Neck and bigsby provisionally sold pending the usual.
  • If your buyer for the neck falls through give me a shout.
  • B16, body and el dorado pick guard now sold. Neck spoken for. Everything else still available.
    plus new stuff added to the first post!
  • ADPADP Frets: 184
    I'll take the Lil 59.
  • STUFF REMAINING:
    • Neck Pickup: Oil City Hardman (uncovered) - see http://www.oilcitypickups.co.uk/televintagehot.html for more details. £40.
    • Bridge: this is from an AVRI Jag or Jazzmaster (can’t remember which) so a genuine fender part.. £25
    • Bigsby B5 Kit - Reliced by MJT in the states. Never fitted. £185 new and the relic job cost a bit too. £140!
    • Allparts Tele Pickguard - white single ply - still in packaging. £10.
    • Reliced chrome neck pickup mounting plate. £5
  • Hup
  • Bump
  • Bump
  • Tele parts still here
  • Bump
  • bump
