If they actually do, you're probably best to get some standard 4-screw ones and drill the extra holes.
Just check the screws are tight and if necessary put a little grease (standard white lithium grease is fine, or vaseline if you don't have any) in the gears and there won't be a problem.
For them to slip, the teeth or the worm gear would actually have to be worn out, otherwise there is no way they can turn backwards under the string tension.
