Heh I have never poked around in a valve amp, so I wondered why on earth it would need 5V and 6.3V!
Thanks.
All-valve digital modelling amp?
That would make sense. So you could be driving four EL34s in the power amp - although at fairly low audio output power, so no need for a big HT current - and possibly 6-10 preamp valves depending on how complex the preamp was.
Nomad
Which Matchless would use a B+ that high? Not the EL84 ones I'm guessing ...
Good call. It must be something of this general spec, anyway.
I still have the power chassis albeit now fitted with a proper IEC mains socket and the eight way connector well and truly disconnected
I know what it is!
