Essentially the 'volume' control is a gain control, and there is an invisible master volume control set to 10 just after the treble control - which is where it would be on a master volume Marshall.
There is no other way to get the power valves to distort even on a MV model - if you turn the preamp volume up and the master volume down, you're hearing preamp distortion.
The only ways to get power amp distortion at controllable volume are with either a power attenuator between the amp and speaker, or with some sort of power scaling.
So even a MV Marshall is just controlling the level going into the power amp. I've clearly misunderstood this completely for years...
So, does this mean if an old Marshall had a loop installed and you plugged the guitar straight into the Return the volume would be full on mental loud?
There are many variations..To K.I.S.Sir, take a single channel amp. Often have one triode stage followed by a volume pot * feeding a second stage, often a 'combination' gain stage and cathode follower to drive the tone stack. That feeds a Master VC which feed the grid of the PI and THAT drive the power valves ..But! There are amps with 'Post PI VCs' and that means the PI can be driven harder. The gains INSIDE the preamp (pre PI) can be various as can the 'voicings', fixed EQs.
*These are often dubbed 'gain' controls but an electronics bod would think that only applies to a control in a feedback loop.
I can recommend Merlin Blencowe's Tube Preamps for Guitar and Bass (don't worry, he goes to proper English with 'valves' inside) Some maths but you don't really have to get it.
Dave.
I can't believe I've just fundamentally not understood how these things work for so long!
And thank you @ecc83 , I will look up that book
I just had another thought - so even a post - phase inverter master vol is *also* not getting any flavour of power valves being over driven, cos it's still controlling the level that goes into the power valves, albeit also allowing you to push the additional (phase inverter) valve. Wow.
So we're back to what ICBM said at the top, the only way to push *the power valves* at low volume is with an attenuater/power scaling.
Talk about every day's an education!
If you can track one down, 'The Ultimate Tone' by Kevin O'Connor is also well worth a read, but you have to be a fan of all things Canadian, particularly traynors
He also insists on showing current flow in the opposite direction to conventional current!
Aaaaalso, Hunter sets out his stall by saying pre-amp gain is crap, it sounds brittle, no-one wants it and power stage overdrive is the holy grail.
I quite like the sound of pre-amp distortion, am I a cloth-eared freak?
If it sounds good then it is good
In fact I much prefer it to the Blackstar HT-Dual which *does* overdrive the valve...
Actually it flows in both directions at once - electrons one way, 'holes' the other. It makes no difference which it is from a macro-electrical point of view, energy is carried round the circuit however you define it. This is why 'conventional current' hasn't been discarded as a concept even though we now know about the existence of electrons.
I don't think 'holes' actually move much IC? Being positively charged atom they are too massive to go fast enough. Then, I SUPPOSE when an electron is 'launched' from an atom it must create a recoil force? Rifles don't move far or fast compared to bullets and I think the rifle/slug mass ratio is much smaller than atom/electron?
But then it is all probably not Newtonian, maybe you have to go bat crap crazy quantum!
But we can't give up 'conventional flow' Flemming and his hand and all that swaddling!
Dave.
Before the discovery of the electron as a particle - which I'm pretty sure coincided with the invention of the earliest valves, which were called 'cathode ray tubes' as TV tubes still are! - it wasn't possible to determine what caused the flow of electrical energy, since the two must add up to zero in a circuit.
