Been thinking about this a while but it really does seem like the large valve head is pretty much on it's way out. Sure there will always be a niche for them but in general nobody seems to want them.
Take my Mesa Roadster that I've been selling, five to ten years ago people would bite your hand off for it, now you can't give them away.
This isn't a moan by the way, I totally understand. I use a powered Kemper most of the time and it does everything the Mesa does, and has effects, clever switching and you have a signal you can send to FOH or your DAW. And it can be a Marshall, Fender, Friedman or anything else.
Thoughts?
However I couldn't sell mine either, so traded it against the studio monitors I now have.
Basically the majority of those previously in the market for a high gain multi channel head have gone digital. And the players who are valve purists probably don't want that kind of amp anyway, they want a simpler and often smaller/lighter kind of amp aimed at cleaner/mid gain sounds.
I'll vouch for the clean channels on the Roadster though, IIRC they are derived from the Lonestar and they're genuinely fantastic.
I think if valve amps survive in the long term at all it will be mostly the simple single-channel types with mostly more vintage sounds, although I wouldn't rule out high-gainers as part of that - bearing in mind most serious pros use multiple amp rigs with external switching anyway, rather than single amps which have to cover all their sounds. Even if they do use channel-switchers, they're usually set to one channel and they use more than one if they need different sounds, so each one can be optimised for one sound and mic'ed separately.
The EVH EL34 50 looks like it could nail it - compact covering the 3 basic tones of clean, high gain crunch, and high gain lead. But almost everything else misses the mark in some way - shared gain/volume controls (previous EVH 50) no proper clean channel (lots of amps) too big/heavy (lots of amps). It's about 5 years too late for a lot of people though.
He was using a JCM 900 100 watt head through a 2x12 cab. Early on the gig, the decibel meter on my phone read 87.5 dB....
Unless you’re a pro player in huge venues I just can’t imagine wanting that much power.
Was yoos in the bog in the pub next door Rich? 100W into a decent 2x12 should put 100dB SPL into the room, 120dB at a metre!
90dB is not that loud, my lad's 15W dommy clone could do that into a V30.
Dave.
I was watching the Pedal Show episode on attenuators earlier. Their 50w Marshall sounded fantastic, the LazyJ 20 sounded Shit. To me.
Clearly a taste thing! But if you want *that* Marshall experience... it's a big amp thing.
And you’re almost right - I did spend a fair amount of time in the bog just to give my ears a rest.
I don't get why people think 100w heads are heavy and impractical. The head itself weighs under 20kg, and paired with my Orange 1x12 fitted with a Celestion Century Neo that weighs only 12.5kg, they can easily be carried in a single trip. In fact together they weigh less than some 2x12 cabs alone.
So personally, I see no reason whatsoever to switch to something smaller. I must admit I've never played a modelling amp in anger but it's hard to imagine anything that can beat a Dual Rec set to ch3 modern in terms of pure chest thumping power.
That said, since I became the temp custodian of the recent HarrySeven haul, Ive had the pleasure of trying all sorts of amps, valve heads, Hybrids, SS, small to large and I have to say some are quite impressive, so I can I will end up hanging on to one or two.
https://twitter.com/spark240
Reddit r/newmusicreview
Blackstar S1 104is 27kg, about the same as my closed 2x12, EVH 100 is really wide and about 25kg IIRC.
I have no idea how Mesa get more stuff into a smaller and lighter head but they do.
It's stupidly heavy, massive in physical size but it does have power scaling from 20w - 200w so it doesn't have to rip your head off.
It's an immense amp and in many ways I'm glad they messed me about.
Me too.
Now is the time to get a JCM800 2203X.
No vintage value and a low used market value because of the trend towards digital tech/modellers.
Hey it's the 90's all over again!
it's a moot arguable point but i don't feel solid state or digital PAs amplifying smaller amp break up do the sound justice. and smaller amps break up in a different way to bigger amps. sooner and higher.
i'm no amp tech or physics grad, so i accept this is a personal anecdotal and instinctive/intuitive impression.
so 100w totally valid for gigging and recording musicians who work on a certain scale.
for bedroom poseurs who want something at home that looks impressive, links them to a musical hero who inspires them, and may feel fancy amp ownership entitles them to present in communities as a serious and fully paid up real musician, the case for huge amps (that could be subbed with smaller or ss/modelling) is also subjective, but less convincing.
to be brutal, that's probably a greater number of big amp owners than than gigging recording musicians who work on a big room or studio scale. but that's a capitalist society disease and not limited to musicians. insecurities aggravated by advertising and peer pressure, buying crap you don't need to get 'serious contender' status within a subculture to which you aspire to belong, expressing your identity through purchasing activity as a displacement activity or distraction for not being able to achieve real things in society at large, etc.
and then there's the sheer big-desire-gratified joy of ownership of a fancy thing.
personally, i think 30w for guitar is a good starting point to work up from to bigger stuff, if you go on to bigger and more pro things. and 50w if you play bass, to cut through. and a decent PA can carry the volume up and distrbute around the venue as necessary.
but if you regularly play bigger venues that keep crap PAs, then there's still a place for 100w.
