I've recently acquired a used M9 so not 100% sure how the switches are supposed to work but I'm sure I should be able to effectively save 6 'pedals' per scene?
However with this unit if a switch on the bottom tier is turned on it will automatically turn off the corresponding switch on the tier above. i.e. 1a will turn of 2a, 2c will turn off 1c. Effectively I can only have three pedals on at one time and no two that are vertically above or below from each other. Surely this shouldn't be the case.
Any M9 users out there to shed some light pls?
This was still pretty good for the time
In these days of FX8s and Helix it does seem like only a few but I was able to do just about everything with 4 FX and a wah
You get used to setting up pairs of things you don't want to use together
I think I had mine setup as [ Whammy +12 / Phase ] into [ Big Delay / Flanger ] into [ slapback / Reverb ].
So I always had a way of pitch shift & mod, or delay & mod plus some kind of reverb/slapback to give some "space" to clean sounds
As soon as one pedal is selected, if the pedal directly above or below was on, it is automatically turned off.
