Victory V30 or Friedman Runt 20 or Sheriff 22
the_mechanicthe_mechanic Frets: 9
edited October 2017 in Amps
Hey guys,
what do you think about this two (EDIT: THREE) amps? Someone owns at least one of 'em?
I'm very curious because it seems they sounds amazing and they're very portable, which one would you choose and why?
  • FortheloveofguitarFortheloveofguitar Frets: 4290
    edited October 2017
    Never played a Runt but owned a V30 for a day lol
    One of the worst amps I've owned. Dull and lifeless. Very disappointing
  • I owned a V30 briefly. It's pretty much impossible to get both channels balanced nicely with the shared EQ.
    If you dial dial up a nice full clean sound the overdrive channel is far to dark. Likewise if you dial in the overdrive channel to be nice and cutting in a band mix, the clean channel is thin and lifeless.
  • uncledickuncledick Frets: 403
    I've played through a Runt 20 which was very nice but several people are moving them on for one reason or another.  You're also in Brunetti territory here.  The demos sound fab.  There's a thread down the page somewhere.
  • You're killing the Victory V30! Demos sounded nice.. :(
  • I've got a Runt 20 and I'm a fan. Great clean tones, more than enough quality sounding gain for most. Nice and compact, but the real winner is the xlr output on the back. Straight into an interface without a cab plugged in. Then I can practice nicely with phones on at home or do some fairly silent recording. I've been using it with a friends Zilla fat boy cab and it makes a fair racket. Could be cheaper but hey ho.
  • I've got a v30, and have had it for about 18 months - so seem to be in a different camp. I agree on the shared eq, it can be frustrating - however I have a graphic in the loop, so it's not a problem. I'd recommend an EQ for anyone actually - completely changes the amp.
    I think it's great, and you can get some really good tones out of it - it takes pedals well.
    You do need to put it into the sweet spot, and then shape the EQ into it, thats how I make it sound good, but that might just be me.
    Sounds much better at full volume rather than down low and I really don't like the low power mode, it just sounds a bit lifeless - switching to the higher power mode it much better.
    I like it and works for me, just get to try one and see what you think
  • I have to try it.
    I'm looking into a Sheriff 22 aswell, someone pointed at it.
    By the way, the thing is I already have a Friedman BE-OD, which is a freakin' killer pedal. Dunno!
    Maybe a Victory V30 + Friedman BE-OD would be a good compromise.
  • I have to try it.
    I like the Sherriff, but it doesn't seem to take pedals very well if thats your thing Treble booster, clean boost OK, anything with a bit more colour it doesn't seem to gel with. Depends what sound you are after
  • Well, I'm pretty straightforward. Od, Fuzz, Delay and reverb. Sometime i use wahs
  • the_mechanicthe_mechanic Frets: 9
    edited October 2017
    No other people with some sort of experience with these three amps? 3
  • DanRDanR Frets: 1041
    I had the runt 50 for a while and didn't like it.
    The mini Dirty Shirley works much better and set for crunch to clean up with you volume and a pedal in front to go metal.
    I have owned the V40 and Kraken but not V30.
    Neither lasted long.
