Jazzmaster Trem on a Mustang
JerkMoansJerkMoans Frets: 8794
edited October 2017 in Making & Modding
Ok. One of my favourite playing guitars ever is my heavily modded jazzmaster. Amongst other reasons, the Mastery vibrato and bridge just work so, so well.
https://imgur.com/a/jVs1J
recently I acquired this Kurt Cobain Mustang which I love in most particulars, save the Adjustomatic bridge and trem which are frankly a bit pants.
so I got to wondering. Could a JM system be retro-fitted? Anyone ever tried it? I see there is a manufacturer called Jay Turser doing something similar but I'd kinda like to try on MY guitar...
https://imgur.com/a/xPO5U
Inactivist Lefty Lawyer
  • underdogunderdog Frets: 8334
    No answer for you but my god that Cobain guitar is lovely.
  • FunkfingersFunkfingers Frets: 14423
    If you have the rout for a Jazzmaster/Jaguar vibrato tailpiece at the traditional distance from the bridge, it will expose the spring cavities for the Mustang unit.
    If you deliberately locate the Jazzmaster/Jaguar unit so that it disguises the original Mustang routs, you might not get the necessary string break angle between the bridge saddles and the string anchor plate.
  • JerkMoansJerkMoans Frets: 8794
    Hey thanks, man! It is a bit special, isn't it? Lucky late-night drunken Gumtree find...
    V helpful. Could you remove the Mustang assembly, glue in a chunk of wood and start from there, I wonder...
    The Mustang vibrato rout is, literally, two narrow channels for the tension springs. If you imagine the wood between these two cavities removed, the result is pretty much the correct size to accept a Kahler Flyer or Pro flat-mount vibrato.
    In the specific case of the Cobain model, a properly fixed Tune-O-Matic style bridge replaces the regular moving Fender bridge item. The saddle spacings are different.
  • Sorry I can't help with your question. Just wanted to say you should look out for a Ryan Jarman signature Squier. It's basically a Mustang / Jaguar mix and it's great. A Musuar , Muguar, the way the Jagstang should have been. Whatever you want to call it...
  • SeshSesh Frets: 1841
    Have you seen the Harley Benton ms60 ow? Pretty much a Mustang with a jm/jag trem, albeit cheap and nasty.
    Can't sing, can't dance, can handle a guitar a little.
    wow. That's it! Someone else got there before me... thanks for the heads up!
  • JD50JD50 Frets: 658
    I could be wrong but I'm sure the mustang body is not as thick as a jazzmaster so may be to shallow for the trem?
    Hmm Google images says I'm wrong!
    That's one of the potential problems. I had a chat with a luthier about this last weekend and he thought it could be done. Once I've sold a bunch of shizzle I shall start haunting the Mastery web store :grin:
    edited October 2017
    Ive read something about this on a forum somewhere, if the body is thin (35mm as opposed to 45mm) then I think it is difficult to machine the spring slots deep enough.....I vaguelly remember the springs not being an issue, is there a peg that protrudes down that the spring attaches to from the trem? the length of that is the issue I think......edit, the sprimg tension screw is the issue, a quick google suggests the spring routs need to ge 30mm deep.....if the body is 35mm (it appears some are 33mm) it would leaf very little room for error...
  • bbill335bbill335 Frets: 1373
    Bilinda from MBV did it first!
    So it is do-able. It's on.
    That was a custom build by Philippe
    http://www.dubreuille-guitar.com/
    Yeah a custom nody is the way to go. Honestly, a well-machined mustang trem unit works fine (a lot of the MIJ ones suck) and the stang vibrato is its own thing, different feel to the jag/jm. If the jag/jm trem with a short scale is what you want, I'd say get a jag.
    Or start with one of those Ryan Jarman jobs and mod the crap out of it
    What about one of the new Fender Duo Sonics they released recently? They are all hard tail. Be worth checking them out.
