Hi all
i need your help, I play a les Paul or a tele - I use a Vox Ac15 and I have the following pedals....
poly tune mini
Dunlop mini wah
ts mini
thorpy peacekeeper
Tim
strymon el cap
ep booster
lovepedal baby trem
that is my current order - I am unsure how to use my Tim and PK. I was thinking of using them with two levels of gain to let the amps characteristics come through. Or use one of them like my “drive channel” type pedal and the other as a boost. But I can’t decide which is best
what order would you have it? Would you have a proper higher gain pedal instead?
Anything you might add?
The EP boost would work well in front of your drives, to give them an extra kick or smooth out any grittiness (that you don't want). I don't know anything about the Peacekeeper but I always thought the Tim was another flavour of transparent boost/drive , so again would be best in front of any other drives. You could get a higher gain pedal, it depends if you gig really; it's certainly a lot easier to hit just one button rather than two when you want that particular sound.
Ultimately there aren't really any hard and fast rules about pedal order. Play around with the order and go with what sounds good to you. Some things that shouldn't work sound great and vice versa.
So signal chain would be whichever sounds better out of:
Tuner - Wah - Tim - TS - Peacekeeper - EP - Trem - El Cap
or
Tuner - Wah - Peacekeeper - TS - Tim - EP - Trem - El Cap
Thanks guys
I went with this in the end (at the moment lol)
Tuner - Wah - TS - PK - Tim - Trem - EL Cap - EP
I have an EP booster clone in my effects loop purely to boost volume for the odd occasions I need to get over a particularly enthusiastic drummer.
