Fender Starcaster questions
martmart Frets: 5205
I've finding myself really tempted by the look of the Starcaster reissues, especially the cherry burst, but there are a couple of things I wanted to ask before I take the plunge (or to help persuade me not to!)
I gather that the stock pickups are simple humbuckers and not proper wide-range pups. But what is the difference sound-wise? Can anyone describe to me how a wide-range pickup should sound - in what way is it different to a regular humbucker?
Secondly, is there any way of putting a trem on these? I've got a few hard-tails, but really miss being able to just add a light shimmer to chords with the tremolo arm. But a contoured and offset body looks like it could be a pain to get anything retro-fitted.
  • OilCityPickupsOilCityPickups Frets: 10357
    A WR ... that is a proper one, has a big, fat, doubled up single coil sort of sound. Not any real mid compression, but big fat bass, juicy mids, and stinging highs. Some feel this sound is a bit OTT ... as it is very 'separate' on the strings, and did I say fat? That's fatness without mud :-)
    They are an acquired taste ... capable of driving an amp quite hard, but requiring sensitive EQ-ing if they aren't going to sound overpowering. Not a pickup for metal really!
  • ICBMICBM Frets: 72304
    It looks to me like you could put a Bigsby on one quite easily - but the B5 horseshoe type not the B7 trapeze. If you don't want to drill holes, the Vibramate V5 should fit.
    I have been thinking about this too! Although I'd still have to get past the carpet slipper headstock, which I've never been able to so far.
  • martmart Frets: 5205
    Thanks Ash, I was hoping you might chip in. So, let me get this right, a proper WR is, er, fat, fat, and fat. :)
    Not good for metal, and fat but with good separation ... that all sounds good for me; I usually want a very clean sound or, occasionally, something up to sort of 70s rock levels of distortion. Is a WR good clean?
    I looove the headstock! It's like the big CBS headstock taken to the max, somehow echoing the Stauffer headstock.
    I was worried that since, where the strap button is, the body edge isn't perpendicular to the strings, you'd end up with the tailpiece at a funny angle, with it then being pulled in directions it want designed to cope with. But I'm no expert on Bigsbys, so would be glad to hear otherwise.
  • stickyfiddlestickyfiddle Frets: 26961
    Someone on offsetguitars put a Vibramate with B5 on theirs- looked great and they were v happy.
    They excel at rhythm, clean and with crunch ... listen to my hero the Late Mick Green of The Pirates ... his sound was based around a Telewith a WR.
    I did eventually come to love the big CBS headstock on Strats, so maybe there is hope :). (Although I actually think the Starcaster would look far better with that one, too.)
    That's why you want the B5 and not the B7 (or B3) - it doesn't have the trapeze tailpiece part.
    edited March 2014
    Ah, that is reassuring, thanks! I'll have a look on OSG and check out the details.
    @TheGuitarWeasel, thanks for that. It does sound like it's ticking all the boxes.
    @ICBM, Oops, I hadn't twigged that the B5 didn't reach down to the strap button!
    So now I'm just left with two problems: how much it's all going to add up to, when I get the B5, the vibramate, and a pair of Buccaneers, and how to explain to the wife that I need another guitar.
    Oh, and the fact it'll mean learning how to fiddle with the electrics in a semi. I've managed to avoid doing that before. Surgical tubing is the thing, isn't it?
    You could always just swap the neck and put a Strat neck on it if you really can't stand the headstock. I'm sure there'd be plenty of people ready to take a Starcaster neck off you, just to get the distinctive headstock.
    I suppose so. Canoeists can't be that rare.
