It's fine at home on the 15 watt setting but you can switch down to the 9 watts but that will be 6V6s instead.
I've got the head and it has a fan and various Ohm speaker outputs. I use it with a 2x12 cab.
Once again, don't be put off by the power rating. This is one loud amp when it wants to be and it has enough clean headroom.
My reason for going to Peach was to try some Dr Z amps, namely a Maz 18 & Monza but also tried a Z-Lux. Of the 3, the Maz had the most Vox-type vibe but there could well be others in the Z lineup that would suit and most of them come in both head and combo format.
Jon
