Many fine guitars, mostly MIJ vintage
russianbearrussianbear Frets: 246
edited May 2019 in Guitars £
«1345678
  • russianbearrussianbear Frets: 246
    edited November 2019
  • beed84beed84 Frets: 2408
    Pray tell, what's in the other dozen or so cases?
  • Jack_Jack_ Frets: 3175
    Are there more to come?
  • JerkMoansJerkMoans Frets: 8792
    https://en.wikipedia.org/wiki/Pandora%27s_box
    Inactivist Lefty Lawyer
  • WazmeisterWazmeister Frets: 9526
    I've got a couple of spare cases if you need one...
  • bbill335bbill335 Frets: 1373
    The cigar tube (tailpiece) on your mustang vibrato is the wrong way round. It should look like this:
    The hole for the arm goes nearest the high E string, and the ball ends sit inside the recesses on the tailpiece.
  • poopotpoopot Frets: 9099
    It does look like that... albeit on a left handed guitar!...
  • hasslehamhassleham Frets: 605
    Wow that Greco is lovely!
    edited October 2017
    Nothing to see, just your standard internet fool over here, move along.
    EDIT: but how come the ball ends are sticking out? Is it a RH tailpiece just flipped?
  • FunkfingersFunkfingers Frets: 14422
    Do you have an approximate date for the red Greco? I could imagine @HarrySeven appreciating a Floyd-less RG-type guitar.
    no, it's actually the correct way, cos it's reversed for LH. There's technically no difference where you feed the strings.
  • Do you have an approximate date for the red Greco? I could imagine @HarrySeven appreciating a Floyd-less RG-type guitar.
    it's early 1990s. It sounds like a Strat. Can't technically sound any other way tho, with this bridge and pickups.
    edited December 2017
    LH Mustang Trems simply do not exist as parts. You can only buy RH ones.
  • Will you be getting round to those cases that say Jaguar on them?!  :o
    Following this thread VERY keenly!
