FS: Nickel humbucker covers, gold tele 6 saddle vintage bridge
streethawkstreethawk Frets: 1631
edited May 2018 in Parts £
Parts dungeon clearout:
First up some Mojotone 53mm pole spacing nickel covers
(shiny nickel plate under the plastic finish protectors)
£5 delivered per piece - 3 left.
Same but in unpolished nickel, kind of an aged look:
Priced as above, or all 5 for £15.
A pair of packaged 50mm WD music covers
rrp £11 each, sell the pair at £12 delivered.
SOLD A pair of 49.2mm nickel covers (vintage/gibson PAF sized)
Still have their protective covers but could use a polish if you're the picky type. SOLD
£9 delivered the pair.
Allparts 'wide spaced bridge' set
£10 delivered
52mm nickel cover, never fitted but no protective cover, might need a polish:
£4 delivered
Wilkinson gold tele bridge with six stamped saddles. Drilled for both string though body or top load.
Used, fine scratches/flaws to finish etc.
£7 delivered. SOLD
Paypal gift, or add whatever fees to prices pls.
  • RedRed Frets: 14
    Hello mate, can I get one of the mojotone 53mm nickel covers? Thanks
    Formerly MusicRadar: deideidei
  • @Red No problem.
    I'm away for a few days so won't be able to post until the weekend. Will message you when I'm back
  • 49.2 covers sold.
  • I'll have a pair of the aged nickel if they're still available..? Cheers
    Still available but pls note the 53mm string spacing. Not sure if it's clear in the description.
  • Hmm, it was, but you've got me wondering now, let me measure again, it's for a 1984 Tokai Love Rock with (I think) their paf mk ii's so possibly not any kind of standard size. I'll get back to you this eve, ta.
  • Thanks for the heads up, not the right size after all!
  • Bump
  • Hey man would any of these fit a standard Seymour Duncan and do you have 1 50mm going?
  • @Tat2dstesh as you can see I'm caught in the site quite box issue. Grr. Anyway you can have a 50mm cover for 6 quid. The Duncan covers use 49.2mm or an odd proprietary size. So no, the 53 won't fit.
    Bump
  • ricorico Frets: 1220
    What are the chances of raw nickel covers with a 50mm spacing being somewhere in the parts dungeon?!
    Zero!
    I only do 49.2 vintage spaced. Sorry.
  • Hi @streethawk do you still have the Tele bridge? Do you have any pictures of it?
    Thanks.
    "As with all things, some days you're the dinosaur, some days you're the monkey." Sporky
    Thanks.
    Some scratches and little spots of slightly thinning gold plate. The white bits on the side walls are just reflections. It's in OK condition for £7!
  • Looks good, I'll PM you.
