http://www.tubeampdoctor.com/en/shop_Amp_Parts_Hardware/Vent_grill_gold_mesh_for_Marshall_style_amps_1793
Yes, you can buy 'expanded aluminium' from B&Q, probably Wickes. They tend to stiff you for the cost but what can yer do!
Dave.
Ooooo!
https://www.screwfix.com/p/alfer-16-x-8mm-perforated-stretched-metal-sheet-grille-steel-250-x-500mm/1596P?kpid=1596P&ds_rl=1245250&gclid=EAIaIQobChMI_4XWt7mi1wIV4bftCh3VDg_gEAQYAyABEgIt6PD_BwE&gclsrc=aw.ds&dclid=CLW077u5otcCFY0K0wodbZ8JCA
I was searching for some the other day - lots of options on ebay
https://www.ebay.co.uk/sch/i.html?_sacat=0&_nkw=aluminium+mesh&_frs=1
Instagram
https://modulusamplification.com/Search.aspx?k=mesh
But you can buy bigger parts at most bigger BnQ shops
Dont buy the 16 x 8 stuff listed above, you really want 10 x 5 type material to provide any protection and to look like something decent
Your cab builder was being pretty cheap to not supply it
Cheers
Michael
If you don’t put mesh on the back of your amp heads, fine. Some Mesa amps are pretty much open at the back.
But don’t try and make the buyer feel guilty. He was the one that agreed to build for you at that price, not your fault if he under quoted!! Ridiculous!
Rift Amplification
Brackley, Northamptonshire
www.riftamps.co.uk
but then it was a 2 minute job t o cut to shape and bend the top edge back over a chopping board... and i have loads left to do a back panel
Instagram
I’m going to pick some up tomorrow if the builder doesn’t come through (posted on Tuesday apparently) I’ll also give the big reveal as to who the knobhead is.
