These also have the choice of a valve(18w) or solid state rectifier (20W) which to me seems to tighten up the sound on the solid state already I generally use the valve.
As usual on these the controls are quite interactive and I set it up for my most overdriven sound and then turn down guitar volume for cleans. I also use an EP booster to just five the front end a slight clean boost. You can also jumper the channels to mix the normal,treble channels to get best of both.
Hope this helps,
Dan
