Unfortunately that's a very difficult guitar to add a trem to, and especially cheaply. As well as some sort of trem tailpiece, you will need to change the bridge since the saddles aren't grooved and the strings will slip off. (You may be able to get away with some cast-block saddles, some of those are grooved.) You then need to make sure there's enough clearance for the strings to pass over the top of the back edge of the bridge, and to keep enough break angle over the saddles you will need to shim the neck fairly heavily.
I went through a lot of discussion about this for a customer a while ago…
He sold it and bought a humbucker Jaguar in the end - it was easier and cheaper.
