How much can we trust reviews the new Marshall DSL's are going to get ?
TelejesterTelejester Frets: 743
If the very first review of any of the new dsl's is carried out by Tom Quayle it will be the best amp he has ever played, we all know this and that is why his reviews are worthless. If lee anderton reviews one they will be magnificent because he has a warehouse full of them that he is trying to flog. If Shane Diorio on the other hand finds they are a pile of shit, then he will pull no punches and will deliver unbiased and factual opinions.
Im real keen to try the new dsl20 hr head but I do know the older dsl's are hideous under the lid and i hope this wont be repeated. Marshall will be keeping an eye onthe reviews for sure, Quayle, Guitarist magazine, Chapman, Lee Anderton and their gushfeast biased reviews arent worth a damn........so where do we go to get the real lowdown ?
«134
  • StefBStefB Frets: 2350
    Your nearest dealer to give one a whirl personally?
    0reaction image LOL 0reaction image Wow! 11reaction image Wisdom
  • crunchmancrunchman Frets: 11446
    They are unlikely to let you open it up to see how well it is built though.
    The Peavey Classic 30 sounds good but I'd never buy another because of the way it is built.
  • PlectrumPlectrum Frets: 494
    Is Shane Diorio that intheblues gobby little bloke? I don't put any weight on his opinions about anything. I agree with you about the rest of them. Basically I'll wait until Marshall put up some demo videos and form my own opinions.
    Really though there's no substitute for trying one yourself.
    One day I'm going to make a guitar out of butter to experience just how well it actually plays.
    i wouldnt say he is gobby, id say he is passionate
  • I'd suggest watching a variety of videos, including the home-grown ones, and form your own views. More importantly, try one out with your own guitar (and possibly favourite pedal) at a dealers. In terms of assessing build quality or durability, you could try to take peak inside to see how it's built if you know what to look for. Guitarist magazine reviews do provide an assessment on build, albeit limited in scope.
  • mixolydmixolyd Frets: 826
    I don’t have any problem with what he has to say but his playing really rubs me the wrong way.  I wouldn’t take gear advice from someone whose playing I find so tasteless.
    I've said it before, I toured with old DSL's, hundreds of gigs every year, shit venues, cold vans, sweatbox festivals and it never missed a beat. I know plenty of guys who did the same. They've got a bad rep because there are so many out there, you're bound to get more failures.
    To be fair they have known issues, I've currently got the "channel switcher jammed on gain channel" one I'm trying to deal with.
    But I'll fix it, and I'll keep fixing it, cos it sounds fucking great.  I have zero interest in the new ones, or any other amp, cos it sounds fucking great.
  • ICBMICBM Frets: 72254
    edited November 2017
    The current Vietnamese-made series is much better than the previous UK-made series.
    Up to a point. It's not so much how many fail - although it is quite a lot, even in relation to the number out there - it's *why*. The type of failures shows serious design flaws and possibly a material quality issue.
    Blown transformers are common - partly because both the amps and the cabinets use a poorly-designed impedance-switching system which can leave the amp with no load, partly because they're just not very good quality.
    Burnt-out main PCBs are common because the layout is terrible and the material isn't good enough to withstand the voltages across it. Marshall had at least two goes at re-designing it and still didn't fix it completely.
    Any of these failures is a roughly £100 parts, plus labour, repair - even if valves don't blow as well (they often do). Repair bills well over £200 are not unusual.
    There are several other more minor faults too, including bias runaway or outright failure which can destroy the whole set of power valves.
    Compare them to the other really common valve amp - the Fender Hotrod series - and although the number of failures is probably roughly similar, the severity of the ones on the Marshalls is usually far worse. It wouldn't be an exaggeration that I've changed more than ten times as many transformers on Marshall DSLs and TSLs (same amp apart from the control section) as Fender Hotrods, and I've never had to replace a board on a Hotrod (Blues Juniors are another matter!).
    I don't deny that you may well have used DSLs with no trouble - you were lucky, or at least not unlucky. The proportion of failures means the majority of users probably don't experience them, but it's still far higher than it should be.
    Ask any tech, not just me.
  • Buy one from Andertons, try it and send it back if you don't like it, you have 14 days for full refund at Andertons and 30 days for exchange.
    That's the best review.
  • John_AJohn_A Frets: 3775
    Are they not obliged to give you 30 days with refund under DSRs?
  • FuengiFuengi Frets: 2849
    I think Shane Diorio's reviews are genuinely done, I just don't think he's got a particularly good ear.
    For example, he made a series of videos about the Fender Mustang III amp and how you couldn't tell it apart from the expensive valve amp it was modelling.
    How to put this delicately... Utter bollocks, it is a dreadful sounding amp that doesn't even begin to reproduce a valve tone.
    He seems to lack nuance, subtlety and detail in his playing and I think that translates into his reviews.
    Just my opinion
  • hywelghywelg Frets: 4303
    You cannot trust anyone's ears but your own.
  • gubblegubble Frets: 1746
    Is that the chap who takes things apart in his living room, wears a baseball cap and usually starts his videos saying "it's me I'm back" whilst doing some jazz hands?
    No, 7 days is the minimum legal cancellation period. The Distance Selling regulations are now the Consumer Contract Regulations.
    no, that is tony mckenzie
  • NerineNerine Frets: 2097
    Wait...
    They've redone the DSL again?
  • ricorico Frets: 1220
    Nerine said:
    Wait...
    Keep up at the back!
    I cannot stand that guy.
    to his credit he is no tom quayle saying everything is magnificent, if tony thinks something stinks he says so
