This ones a bit of a challenge. Its been heavily modified throughout its life and i have been challenged with putting it back to a normal configuration, without making it look like a brand new guitar or a purposeful relic.
Its one of those jobs that doesn't make the most economic sense, but its not always just about that. My first guitar was very similar to this, and also got modded whilst I was still finding my way, so its kinda cathartic to get to put something so similar back to its old state. The good news is i still have the abused neck from my old one. Its beyond saving and has been used as a paint stick. It will be used as a donor for some of the wood plugs needed here
I will start with some structural fills front and back. Once they are done i will inlay a new centre section. then if the joins ever reappear it will look like a 3-piece body
the neck needs the nut shelf rebuilding and some plugs front and back. its already had a new fretboard but it is very flat so needs a re-radius and therefore a re-fret too
http://www.rabswoodguitars.co.uk/
https://www.facebook.com/RabsWoodGuitars/
My Youtube page
the finish was a bit rough but you can see most of the previous work was done fairly well. It’s all solid and plays well even if the neck pickup and Floyd route could be neater.
Instagram
New finger, board refret, infills.
someone loves this very much to do so much work
as always follow WezV projects with interest.
Yeah well as you say, should be an interesting project... and I agree its not always about the economics.. I want to help provide people with guitars they want the way they want them.. You cant always get that off the shelf.
And a guitar with sentiment.. If you get that right (which im sure you will) will bring the owner immense joy.. Which in itself is priceless and worth while I think..
My Youtube page
It does have huge sentimental value that for me way outstrips any sanity in having the restoration done and fundamentally it's actually a pretty good guitar to play.
My sadly now departed father in law helped me do a lot of the modifications well over twenty years ago when I wasn't in a position to go and buy a guitar that had the features I wanted. Plus like all modification it's fun to do.
It's by no means Trigger's broom but I will admit to it having had a new brush head or two over the years
I recognised that I have very little of the woodworking skills required to bring it back into something like stock and I'm incredibly grateful that Wez has agreed to take on the challenge.
I will approach this squier the same way I would a vintage strat, because the next one might be.
anyway, the body paint is off. its all good wood underneath. and i can soon start on the structural stuff. the contours are really quite nice on this
Instagram
you can see that most of the previous woodwork has actually been done pretty well
I have made grain matched plugs.
the ones on the body are just to take care of the deepest holes, they will allow me to keep more of the original wood in place
the ones in the neck will be visible when done, but are drilled from the headstock of my old, thoroughly dead, squier neck.
i found a spare slab of basswood to do the rest of the work. i used it for the plugs here, its a good match
Instagram
Great to see this - no, it makes no sense financially but so what? Things don't have to make sense to be superb.
I assume the original pickups are long gone.
This is not an attempt to put this back to an original state
Instagram
Suffice to say, they'll not be going back in
