Ebony ones have a slight advantage that they don't bend under pressure of the ball end like soft plastic ones can, although if yours are hard plastic this shouldn't be an issue anyway. Bone ones don't bend but can chip. If you like them there's nothing wrong with making your guitar look nice - I have bone ones with a pearl dot.
thanks for your reply, really helpful
I have some nice boxwood pins in my Seagull (Planet Waves ones, I think), and I reckon I'll go for bone with abalone dots for my Martin.
The strings are anchored by the bridge plate, not the pins.
You're absolutely right - if the guitar is strung properly, all the pin is doing is preventing the ball end from moving back into the hole, not holding the tension of the string at all - that's taken by the bridgeplate. The pin doesn't even have to be very tight in the hole, in fact - just enough that it doesn't come out - this is a common mistake, and if they're pushed in too tight it makes getting them out difficult.
