Tone cap toggle switch?? Help
I want to wire a Capacitor toggle switch but only want to switch between 2 caps, the link is for a 3 cap toggle, what do I need to do to change it for 2?
Which one do I need to use?
Any help is greatly appreciated, especially diagrams :)
Fretboard Feedback https://www.thefretboard.co.uk/discussion/58705/  ALSO Over 500+ 100% feedback eBay transactions
  • frankusfrankus Frets: 4719
    edited March 2014
    The top one will do it. (AKA as an SPDT single pole double throw).
    Wire both capacitors to the lug and to the throws of the switch... then take an earth wire to the common lug of the switch..
  • mrn1989mrn1989 Frets: 240
    Like this?
    edited March 2014
    yep
    that'd do exactly the same as I described :)
  • ICBMICBM Frets: 72307
    frankus said:
    yep
    But is better :P , because it doesn't leave the unused cap hanging on the signal path where it can act as an aerial and pick up noise.
    For what it's worth, this is exactly the method I used to prove conclusively that cap type/brand/construction/etc makes no difference in an electric guitar, if you're interested in trying it for yourself.
  • CirrusCirrus Frets: 8491
    Out of interest, where do you think it makes a difference? I switched a silver mica coupling cap for a ceramic and heard a difference a couple of nights ago, but this is with the best part of 200v sitting across it. Do you think it makes a difference on amp bright cap positions?
    edited March 2014
    It makes a difference for coupling caps where there is a high signal voltage applied to the cap, especially when it's a large proportion of the voltage rating of the cap. The reason is simple - self-distortion, caused by the dielectric properties being modified by the voltage. If the voltage changes, the value of the cap is effectively changed, which affects the signal passing through the cap, so the result is harmonic distortion.
    If the bright cap is across a resistor or volume control with no large voltage on it, it shouldn't - but it might if it's in a place where there is enough voltage.
    And it won't at all in a guitar, since the voltages are tiny even compared to the lowest-rated caps (usually 50V for non-polar types), and the cap is to ground anyway - rather than the signal passing through it - so the part of the signal with is affected (harmonics) are exactly those which the cap is removing from the signal.
    Im going to use a 0.015uF and a 0.1uF to get the total opposite in tones.
    This is the diagram Ive just drawn to follow, is this correct?
    Yes, that's right.
    Cheers guys
    ICBM said:
    frankus said:
    yep
    Always so rewarding :D have a wisdom, Sir.
