For example a Yamaha PA where there powder coat had not been scrapped of the chassis to make a good ground connection.
The earth tag must be crimped NOT just soldered.
My understanding of the regs is that a self tapping screw is not acceptable.
The best method is to use a bolt welded to the chassis, although few amps use this method.
You also need to ensure that the correct 12mm picture sticker is used, something that is rarely done.
Rift Amplification
Brackley, Northamptonshire
www.riftamps.co.uk
I would never connect anything else to the safety earth ground (it would not be good practice in audio regardless of the regs; the audio should be grounded to a single point near the input), but my understanding of the old regs is that it is acceptable to bolt other earth connections on top of the safety ground.
I've certainly seen this approached used in kit that has been through approvals.
As I'm sure you know the regs are in the process of being updated, and I've not yet ploughed through the latest revision regarding earthing.
I've had that issue too; can be a real pain.
Many, many years ago I did a one day course at Sharp Electronics to get my PAT tester's ticket (back in the day when retail electronics was a decent trade!) and we were made very aware that certain equipment was not to be zapped with 1000s of volts!
Dave.
https://www.ebay.co.uk/itm/Marshall-Lead-20-Combo-Amplifier-378/132431140486
Have a look at the pics of the back.
Lol!
"All items have been tested". So that's ok then.
