The Schaller is called a megaswitch. Is that just ego or does it have more switching options than standard 3/5 way switches?
https://www.allparts.com/EP-4276-000-Schaller-Model-E-5-Way-Megaswitch_p_4933.html
I'm not sure how that one works so not sure if one of the Oak Grigsby would be a viable alternative.
Oak Grigsby make a single wafer superswitch and a double wafer superswitch.
StewMac have an OG double wafer with the terminals turned inward so it more easily fits a Tele control route.
http://www.stewmac.com/Pickups_and_Electronics/Components_and_Parts/Switches/Oak_Grigsby_Super_Switch.html
SIngle wafer for less than I can buy them trade.
http://www.toneshapers.com/switch-5-way-oak-grigsby-2-pole-superswitch.html
https://www.banzaimusic.com/CRL-5-Way-Super-Switch.html
Oak Grigsby do them as well, but I've found the quality slightly lower than CRL.
The Megaswitch has preset different options from the standard 5-way. There are a couple of ways that you can wire them up to do different things. They are far less versatile than the CRL Superswitch though.
The problem with the Superswitch is working out how to wire it all up to give the options you want, since it's a pure 4P5T switch with no fixed wiring.
Does it have the spring like 3 and 5 ways?
The twenty four contact 4-pole Superswitch that ICBM described is now also available in a narrow format. (Basically, the spacers between the contact plates are shorter.) These can be persuaded into the regular control cavity of a Telecaster without modification. They should fit the EBMM guitar too.
The pickup coil permutations offered by the stock PCB switch can be replicated on the CRL Superswitch. You can probably find the correct schematic diagram on the DiMarzio Support web pages. These will even have the correct conductor colour codes.
I have a Megaswitch P in a PRS SE Custom 24. I have photographs of its control cavity stored in my computer. (I’m posting this via my smartphone.)
The official Schaller schematic diagrams illustrate where the connections go on the switch terminals. They take little account of the other controls that might be in your particular guitar. More importantly, the diagrams take no account of pickup output conductor insulation colour codes.
I've had a few circuit board type switches from Schaller (Mega Switches) and also Gunther Eyb/Goldo variants (I prefer the latter over Schaller due to the dimensions of the blade). I think they have the best action of all blade switches. If you overheat the boards whilst soldering you'll have trouble, but if you treat it appropriately they are fine, and certainly no reliability issues in use. I can't say the same for some of the traditionally constructed Superswitches I have had. I think a lot of the bad rep for circuit board switches is down to the really cheap ones found in entry level guitars, or because people approach wiring them wrong - go in with a 60W soldering iron and glob a huge amount of solder on and leave the iron in contact with the board for an age and of course its going to get ruined.
One thing that all Superswitches suffer from is the break-before-make action, which is unlike traditional 5-way switches. That brief silence and/or click between positions annoys the hell out of some people and doesn't bother others. If you want the versatility a Superswitch offers then that is the compromise. Accept it, or keep a standard switch and don't expect the same level of versatility, or perhaps cover your guitar with a multitude of extra switches...
As an aside, Schaller also make some of their Mega Switches as rotary versions, presumably for PRS owners.
http://www.thefretboard.co.uk/discussion/89942/caspercaster#latest
