http://www.thefretboard.co.uk/discussion/comment/1679852/#Comment_1679852
Basically you could connect it in series or parallel. Some preferred serial (i.e. JMP1 > Processor> Amp).
I preferred to connect my processor in parallel, which then required it to be run 100% wet (doing the mix in the JMP1).
either:
jmp-1-> g-force left input
gforce left output -> jmp-1 FX return left
jmp-1 left main output -> power amp
or
jmp-1 main out left -> gforce input left
gforce output left -> power amp
