DRL CT09 Thinline Electroacoustic Guitar LR Baggs Anthem with 9V DC Phantom Power £650
jaymenonjaymenon Frets: 813
edited January 2018 in Acoustics £
For sale is my DRL CT09 Thinline Electroacoustic guitar - in used but immaculate / beautiful condition.
Cutaway thinline electro-acoustic.
Body: Hollow chambered solid mahogany
Top: Solid European spruce top (no sound hole - so very, very feedback resistant)
Neck: Mahogany
Contoured / Chamfered Heel
Fingerboard: Ebony with Abalone inlays
Gotoh 510 tuners with Ebony Buttons
On board electronics upgraded to an LR Baggs Anthem dual-source system which involves:
1. Undersaddle 'Element' transducer
2. Bridge Plate mounted internal 'Tru-Mic' microphone
...with the ability to mix variable levels and blend between the two sources.
This goes beautifully with a LR Baggs Venue DI Preamp ( which I plan to list shortly)
'Phantom Power' supplied via a TRS cable which carries
1. Audio output from the guitar (to an amp/PA system) and
2. 9 volts DC to the guitar from an external power supply unit (included)
... so you never run out of power the middle of a gig.
Original Hard Case
<a href="https://imgur.com/AGmBJQz"><img src="https://i.imgur.com/AGmBJQz.jpg" title="source: imgur.com" /></a>
<a href="https://imgur.com/5VE2JQd"><img src="https://i.imgur.com/5VE2JQd.jpg" title="source: imgur.com" /></a>
<a href="https://imgur.com/wRyYsBs"><img src="https://i.imgur.com/wRyYsBs.jpg" title="source: imgur.com" /></a>
<a href="https://imgur.com/6VyRX72"><img src="https://i.imgur.com/6VyRX72.jpg" title="source: imgur.com" /></a>
<a href="https://imgur.com/rMCBV5M"><img src="https://i.imgur.com/rMCBV5M.jpg" title="source: imgur.com" /></a>
<a href="https://imgur.com/16FOCoA"><img src="https://i.imgur.com/16FOCoA.jpg" title="source: imgur.com" /></a>
<a href="https://imgur.com/EzlIxtQ"><img src="https://i.imgur.com/EzlIxtQ.jpg" title="source: imgur.com" /></a>
<a href="https://imgur.com/p8EQ59c"><img src="https://i.imgur.com/p8EQ59c.jpg" title="source: imgur.com" /></a>
https://imgur.com/gallery/Lv2So
