FiiO E11 A3 Portable Amplifier for Headphones
StavrosStavros Frets: 335
Does anyone know if this could be used as a travel amp combined with headphones and a suitable 6.35mm female to 3.5mm adapter?
I love my brick
  • Probably not, it would only be able to do cleans and the input is the wrong impedance.
    You would need some sort of pre amp alongside it.
    Look at the Vox Amplug series.
  • ecc83ecc83 Frets: 1631
    Some years ago I built my son  a pre amp for his Strat using the LM386 1W amp chip. Even though the input Z is far too low at about 10k it sounded quite good.  P of P to fit a FET buffer anyway.
    Dave.
  • StavrosStavros Frets: 335
    Mmmm ok thanks guys. It was a Christmas pressie, so might have to look at a Pre amp.
    I love my brick
    edited December 2017
    If you have any kind of pedal NOT of the daft "True Bypass" sht, just buy a Behringer HA400.
    Or! Should you want to record on the lappy, a Behrry UCA 202. (+pedal)
    Dave.
