Patch Cables
kswilson89kswilson89 Frets: 222
What patch cables do you use? Looking for a single, quality brand that does various lengths with right angles jacks.
  • Diago solderless or home made.
  • I use Mogami and Planet Waves, PW are slightly more affordable, though with Mogami I've not had any issues with my rig in 6 years.
    You can get those custom build yourself ones by George L's as well so you can cut it to desired lengths.
  • simonksimonk Frets: 1467
    Make your own with Neutrik jacks and van Damme cable, or get designacable.com to do it for you.
  • ICBMICBM Frets: 72227
    I would not actually use Neutriks for patch cables - they're expensive, not very low profile and have surprisingly high capacitance - that's not a joke, for a short cable the capacitance of the plugs will be higher. The super robust construction isn't necessary if they're just going to be static on a pedalboard.
    Switchcrafts or some other more traditional plug are better for this.
  • Oh @designacable is a good shout. Had a lead made recently and it was excellent.
    I meant to say Hicon pancakes actually...
  • ecc83ecc83 Frets: 1624
    I agree the Nuky R/H plugs are too fat and expensive where their BSH qualities are not needed. Surprised at the capacitance point but then never measured any.
    A note on 'pancakes'? Either sleeve with H shrink or steal a bit of Her's nail polish to lock in those infernal, tiny screws!
    Dave.
    I was very surprised too! It’s not *huge* - around 40pF per plug, from memory - but it’s enough that if you’ve got a dozen of them on an all-true-bypass board then it does become noticeable, and it’s more than the capacitance of a typical 6” patch cable.
    (Yes, I know what you think about all-true-bypass ;). So do I :).)
    My guess is that it’s because the two conductors in the plug shaft are much beefier than usual, and the insulating plastic sleeve correspondingly much thinner.
  • I originally went for the Planet Waves Solderless kit which worked out pretty well. The only problem I found was the cabling to be a bit thick and therefore didnt always bend into the right positions. So then I went for the George L stuff and I love it. Probably wont need to use anything different ever again.
  • JEPBLEPJEPBLEP Frets: 188
    I used Evidence Audio SIS plugs/cable. It's not cheap, but it's fail safe and I like supporting 1-man bands that stand by their products.
  • GavRichListGavRichList Frets: 7150
    edited December 2017
    Lava Ultramafic for me. Cost a small fortune, but it's done now and I have no complaints whatsoever about the cables themselves. Board sounds lovely, never had one fail on me, and I even strangely enjoy making them.
    Did get a message from 3 Monkeys Solderless the other day though, asking me if I'd like to try theirs. They do look the part; very low profile.
  • Thanks for the mention @Teetonetal, We've actually just updated the sale section of our website with tonnes of new patch cables! At least 25% discount off the original price of all our sale cables, you can find those here... https://www.designacable.com/bulk-offers.html
  • VJIvesVJIves Frets: 466
    The Warwick flat patch cables are so good, insanely thin and come in a bunch of different sizes. I'll never go solderless again.
  • SassafrasSassafras Frets: 30289
    I notice Thomann do their own EBS/Warwick type flat cables:
    https://www.thomann.de/gb/harley_benton_fpc10_flat_patch_cable.htm?ref=prod_rel_370951_1
  • TateFXTateFX Frets: 114
    Evidence Audio SiS. Honestly its the best worth the investment.
    Formerly Stu_Tate
    Tate FX
    www.TateFX.co.uk
    Instagram
