Superb isolated power supply. It's an exact copy of the T-Rex Fuel Tank Jr. Cheap as chips too!
http://www.richtonemusic.co.uk/products/truetone_1_spot_combo_pack.asp?gclid=Cj0KCQiAsqLSBRCmARIsAL4Pa9Q1wGEbed1D1WVN6ImK0R8V6VGlIHrRo_wfc2VofKK0jB6laz9g5jYaAme9EALw_wcB
https://www.musicstore.de/en_GB/GBP/Fame-DCT-200-Multi-Power-Supply-/art-GIT0019066-000
For just over £30 I’ve found it really good. Good selection of cables for it.
Downside is it’s massive!
http://i63.tinypic.com/b7gcqh.jpg
Do you mean the original Harley Benton Power Plant? It's a proper big old lump!
I found it be incredibly noisy especially when fully loaded. I presume this is down to there being absolutely no isolation whatsoever!
I did manage to fit one underneath a Pedaltrain Classic Pro but it was definitely a squeeze and I wouldn't fancy its chances if the board was being used on an uneven surface!
The Jr version is much better. If your ma needs are low then it's pretty much faultless.
I assume it isn't a problem to mount the power plant junior under a board? This one is only really for my home studio but you never know what you might want to use it for further down the line.
