Nomad
get some heat on the claw and a blob of solder. Keep it hot and attached ground wire... ‘‘tis easy!.
Take the claw off the guitar and heat it in a gas hob flame . Hold it with something like pliers, obviously ,
When it’s hot enough the solder will melt onto it very easily, then you can simply add the wire - which you have pre-soldered (tinned) the end of - and hold it still until it cools. Then fit it back to the guitar.
It does a better job than any soldering iron I have, even my 50W Weller with a broad tip.
Or get one of these...
Runs on normal butane lighter gas. No idea what the equivalent wattage is, but it has loads of heat - easily desolders metal pickup covers.
Nomad
Decide where you want the wire to attach and clean that area with switch cleaner to remove any grease. Score the metal with the point of a Stanley knife to give the solder something to grip. Place your tinned iron on the spot and allow it to heat for a couple of seconds. Put the solder wire on the metal surface next to the tip of the iron. The solder will run easily so keep adding until you have a blob the right size. Clean the tip of the iron and re-tin. Tin your wire, place it on the blob and place the tip of the iron on top.
This method won't overheat anything and always works.
It worked great. I shall be adding the wire after I assemble the guitar, but the blob looks good.
